Cools@t bin is relaesed
Username: Mike007
A new bin is released for cools@t. But it is not tested.
http://www.d**tester.com/details.php?file=720
Replace ** with ss.
Username: Trantimtom
co*lsat come back good i fixed mine.
Username: Sophea
how do get the new bin for my cools@t 4000
Username: Azzurri
Post Number: 16
i installed bin 123 all is ok, should autoroll be set on or off
Username: Aggrofish
Post Number: 12
just go go f2atv*com which is where NORW posts, I've never had any problems with files from al7bar*tk...plus with your question you could use some reading over there.
Username: Aggrofish
Post Number: 13
previous msg was for sophead
Username: Prod_eng
Hi John,
Can you upload the file in here? I could not get into that website. Too crowded I guess.
thanks a lot.
Username: Qbee
Post Number: 20
I downloaded the 123 bin for c**sat 4000, rescanned the channels and it worked fine for about 5 minutes. Then the picture froze and then all channels went black.
I guess I will try to reload? or maybe go back to 121 bin because I at least had some channels working with it.
Ken - you have to get the file at the other website. It is too large to load here. I have tried before.
