Loading a new bin file on 3500sd?
Username: Sowhatsowhat
I am a newbie. Back in the hu days you had to clean a card and then put a new bin on it. My question is, when you apply a new bin to a 3500 PC-to-Rec., do you just put it on top of the old one or is there a way to sort of wipe the slate clean and then apply the new bin? Thank you in advance.
Username: Vinidomine
Post Number: 65
Ignore the monkey posting pics of his mom.
In answer to the question - no, you don't need to reset the ird before loading an update.
It will overwrite the previous version and work fine from there.
Vini.
Thank you Vini for the post and answer to the question.
