- View Standard Definition/High Definition contents (MPEG2 and support MPEG4 AVC/H.264) - Fully Digital HDMI ( SD/HDTV formats) - Full Compliant of MPEG-S &DVB-S2 Digital & DVB broadcasting - 2 Common Interface - Front USB connection - Card Reader embedded - 950-2150 MHz input Frequency (IF Loop Throughout) - Satellite Scan - Simultaneous Scan with 4 Satellites - Flexible receiption of SCPC & MCPC from C/Ku-Band Satellites - Variable Input Symbol Rate (1-45 Msps) - Video output resolution: 480p,720p,1080i - User selectable output resolution - EPG (Electronic Program Guide) - Multi language OSD - Automatic PAL/NTSC Conversion - Fast Channel Change - 5000 Channels TV & Radio program - Timer Function (Automatic Turn On/ Off by Setting Function) - Conditional Access - RTC (Real Time Clock) - PIP , PIG (Picture In Graphic) - 5 Favorite List & Unlimited Programs per each - Powerful Channel Editing Fuction Sorting: Alphabetic, Satellite, FTA/Scramble, Parental Lock Move, Delete, Favorite Edit Parental Lock, Channel Rename, Channel Skip - Manual PID/ Satellite & TP/ Network Scan - S/PDIF (Digital Audio or Dolby AC3 Stream out) - 1 optical digital output for Dolby Digital and PCM digital audio - Diseqc 1.2 and USALS Compatiable - Comparable of Setting the Frequency for SMATV System - SD Memory card compatible(JPEG,MP3,firmware download) - Software Upgrade via RS-232C (Receiver to Receiver, PC to Receiver) - Component Out (YPbPr) - Universal Remote - OTA
Front-End 1 Input Connector F-type, IEC 169-24 IF Input Frequency 950MHz to 2150MHz IF Loop Throughout 950MHz to 2150MHz Input Level -65 dBm~-25 dBm LNB Power 13 /18VDC / 500mA Max DiSEQqC Control Diseq1.2 & USALS compatible Band Switch 22KHz Tone Modulation method LDPC/BCH(DVB-S2) 8PSK/QPSK, DVB-S QPSK Symbol Rate LDPC/BCH(DVB-S2) 8PSK/QPSK :10~30Msps / DVB-S QPSK: 1~45Msps Viterbi Decoding Rate 1/2,2/3,3/4,5/6 and 7/8 Reed Solomon Decoding FEC: 204, 188. t=8 LDPC/BCH Punctured Code ,1/2,2/3,3/4,3/5,4/5,5/6,8/9,9/10 in DVB-S2
MPEG transport Stream A/V Decoding Demultiplex According to ISO/IEC 13818-1 Input syream Max. 90Mbit/s Aspect Ratio 4:3, 16:9 Video Resolution 1920 x 1080 Audio Decoding MPEG Layer l & ll , MPEG-4 AAC+ Audio Mode Single Channel /Dual Channel, Stereo, Joint Stereo Audio Sampling Frequency up to 192KHz
Microprocessor & Memories Main Processor Trinity(ARM926) CPU Clock 280MIPS Flash Memory 8 Mbyte SDRAM 160 Mbyte EEPROM 32 Kbit
Data port Connector 9 Pin D-Sub Type Protocol RS232 Asynchronous Data Rate Max. 19.2Kbps
RF Modulator Connector IEC 169-24, Male/ Female Frequency 470-860MHz (UHF) Output Channel CH 21-69 TV Standard PAL-B/G,D/K, I,M Selectable
Front Panel 4 Digits LED Channel Number Display 8 keys Power,Channel Down/Up, Volume up/down,Menu,Exit,OK VFD VFD Display
Rear Panel IF Input F-type Connector IF Loopthrough output F-type Connector 6 Phone (Cinch) Video, Audio L, Audio R, YPbPr Scart TV / VCR <---- This we won't get S/PDIF Optical HDMI Type A S-VHS 4-pin Mini- Din Modulator F-type RS232 Serial Port 9 Pin D-Sub Type
Electrical and Mechanical Input Voltage AC 90-250V, 50/60Hz Power Consumption Max. 45 Watts Standby Power Less than 10 Watts Size(WxHxD) 340x245x65mm Weight 2.1kg
Put a HD integrate to receiver I think is not a big deal . The big deal is how to support people . BL back or not is not a big deal . If he want his business go up he must do something . Remember, that is he do for him, not for us .
Technology is the same, important thing is how to make people felling good that is support . Support is gold key .
