Any clone safe bins expected
Username: Mav444
Post Number: 21
any clone safe bins for the 2500a excepted in the near future? Thanks
Username: Gunaa
Post Number: 32
Try this
http://www.*freespaces.com/djragavan/test/pansat2500a-x-85bl_060609_277_au_api_. zip
remove *
Username: The_wank_artist
Post Number: 822
That isn't a clone safe bin. There should be a T at the end such as 277T.
As I've said all along today, you can try that bin and it may or may not work. Use at own risk.
Username: Mav444
Post Number: 23
Thanks yea i know about the 277 bin but it isnt clone safe Thats why I was wondering if one can be expected, But I do thank you
Username: Merlisi
Any news on the clone safe bin for 2500a and how do you know if you have an authentic Pansat reciecer???
Mine says "Pansat" on the left hand side and 2500a on the right hand site (front) it also has a "deseqC 1.3" small logo on the bottom right hand side....It is a gray small box with 3 buttons on the front.
Thanks in advance for any help....
Username: Mav444
Post Number: 26
Future-fta
