Bronze Member Username: SakapfetPost Number: 23 Registered: May-06 | hi i need help to put the bell key i know for dish but i dont know for bell thank you |
Silver Member Username: The_wank_artistPost Number: 774 Registered: Feb-06 | Jr. You've been here for a while now. Read your post and tell me what's missing???? Receiver???? |
New member Username: Adan70Post Number: 6 Registered: Jun-06 | BEV KEYS ARE D1 15 0C 8E 66 82 D9 80 90 A9 20 20 37 07 87 08 ACTIVE KEYS 0C B7 0A F9 50 75 F3 5B 31 EC 79 97 5C D7 CE 1A |
Bronze Member Username: SakapfetPost Number: 24 Registered: May-06 | nothing is missing i just decide to change the dish for bell but i dont know if it the same to put the key for bell like dish |
New member Username: TbedoyaBayonne, Nj Us Post Number: 8 Registered: Apr-06 | how to change from n2 to bell |
Bronze Member Username: SakapfetPost Number: 26 Registered: May-06 | nothing is missing i just decide to change the dish for bell but i dont know if it the same way to put the key like dish network |
Bronze Member Username: RkanakPost Number: 24 Registered: Jun-06 | zee, what you want to change from N2 to bell, ....if you want to change the keys than change the provder id from 01 01 (for dish *net ) to 09 01(for bell)... and nagra2 is not only for dish net it is for bell as well..when you go to CAS menu you will find nagravision2, click on that and then you will see provider id and keys below that... |
New member Username: BncPost Number: 2 Registered: Jun-06 | What location do we move the dish to get Bell? And what are Bell Sats? |
Silver Member Username: The_wank_artistPost Number: 777 Registered: Feb-06 | 82 and 91 degrees, nimiq2 http://www.kusat.com/go.phppath=/install/locate.php |
Bronze Member Username: BalujaPost Number: 13 Registered: Jun-06 | I have Ariza 700 which accepts two, 16 character lines. I was using it for DN. I checked and could not find 0901 foe BEV in Nagravision under Parental Control. Can I use it to watch BEV. btw, i also have Echostar from bell and it has a card too from Bell but not subscribed to bell. Can I use any of the recievers to watch BEV as DN is down. I have one dish installed by Bell guys already. On reciever do I need to do sat scan |
Bronze Member Username: EceCalifornia, California Usa Post Number: 14 Registered: Jun-06 | anybody have key for pansat 2500 i use 71 9C 60 71 04 C1 39 AE 88 FF F0 5E D2 4C F3 FC and no working I try D1 15 0C 8E 66 82 D9 80 90 A9 20 20 37 07 87 08 and no working please somebody have right keys pleease.......... |
Bronze Member Username: RkanakPost Number: 27 Registered: Jun-06 | Rakesh, do the following steps: when you go to the parental control, click on nagra vision 2, you see provider id 01 01 is for DN, right click the volume button once, under provider id, it changes to 09 01 i.e for bell express, btw at what angle you have the bell dish hooked up, if it is at 91W you will get all the english channel, |
Bronze Member Username: BalujaPost Number: 14 Registered: Jun-06 | Rajesh: I dont know the dish angle but was installed by Bell guys and I used to get Indian chanels too. On right clicking the volume it does'nt show me 0901. Can I create it. |
