Keys for fortec classic Na
Username: Sminams
Hola,
I need ur help ,,,
So I a looking for a new keys for Nd (for fortec classicNA ) Cause I lost all channels
and the way to enter in...
thanks
Username: Adan70
Post Number: 7
DISH NETWORK KEYS
E8 70 B0 0A 8E 0A 3D C5
F3 59 C3 5F 1A DA 19 5C
ACTIVE KEYS
71 9C 60 71 04 C1 39 AE
88 FF F0 5E D2 4C F3 FC
Username: Cybercubi
Oncle - There are no new keys, its been posted everywhere here that this is not a key problem. If you got locked out of your receiver, check out this post: https://www.ecoustics.com/electronics/forum/home-video/232873.html.
But you have to wait until a fix is out for Fortec, which I will bet will not be the fastest one out...
Username: Adan70
Post Number: 8
I owned 3 viewsat extreme with new bin files 3 days ago everything working I have DN AND BEV sat
Username: Babakhan
Post Number: 130
How to change the NAGRA2 Key codes
(for Fortec Lifetime Ultra only)
1- Press Menu button on your remote control
2- Press right arrow key 2 times Channel Edit
3- Press down arrow key button 2 times, press OK (Code) enter 1010
4- Press the down arrow key to Set Default Key, click OK
5- Press the up arrow key to Nagravision click OK
6- On your top left you should see Nagravision-1...if not, then you've got the wrong BIN version.
7- Press right arrow key until you see Dish Network on top
8- Press the down arrow key once to Key Number
9- Press right arrow key 2 times the from Key Number 00 - 01 - 00
( Now take notice that on your top left you should see Nagravision-2 now )
10- Then press DOWN button key to change the keys manually on Key Number 00
11- Enter new Keycode, do the same procedure to enter the the keys on Key Number 01
Note:
Satellite Providers changes the stream key codes unpredictably,
(Note: remote control key letters equivalent)
A = Sat, B = i, C = Tv/Radio, D = Pause, E = Audio (speaker), F = EPG
12- Check and make sure that you got all the keys....Press OK to store (save)
13- Press EXIT key 3 times to exit to the channels.
Note:
If you accidentally lock the KEYCODE (OFF) use this default password 1668
Username: British
Post Number: 38
New bin already released. look for it. 060706
Username: Cybercubi
Post Number: 8
Has the 0607 bin been tested? Any news about it?
Username: Sminams
Pls,Can somebody give me the instructions to change the NAGRA2 Key codes for Fortec Lifetime Classic NA
Username: Punjaban_jatti
Hamilton, Ontario Canada
Post Number: 9
OMG Oncle the instructions r givin right there. Read them.
Username: British
Post Number: 43
Test bin at your own risk dont know if it works:
LifeTimeClassicNA_375SUA_XPA_X_XL_060607
Username: Djorkaeef
Montreal, Qc Canada
i have fortec classic & i have those keys too,
DISH NETWORK KEYS
ACTIVE KEYS
but i lost almost all channels, what is the problem????
pls help
