Which receiver are fixed by now
Username: Mc_sunny
Post Number: 9
I Have fortec reciever, when it get fixed wut i need to do ? if someone know help me out plz Thanks
Username: Onlyali
Post Number: 12
watch tv
Username: Moe948
When there is a fix for fortec, you will either have to upload the bin into the reciever yourself or go to a satellite dealer/shop and get it fixed from them.
Btw, the only FTA recievers with fix right now are Viewsat xtreme and Viewsat platinum.
Username: Mc_sunny
Post Number: 10
Thanks alot Moe
Username: Evadelparaiso
Puerto Rico
Post Number: 706
Buy a right cable and you will be ready to do the upload, in the meantime you can learn how to do, try finding all the information.
Username: Maxfun
Toronto, ON
Fortec lifetime ultra. After downloading a new bin, went into factory setting and entered the passwd and hit ok and now I am not able to download any channels at all for any satellites. For ehco 7,disesc 2 shows strong signals 75-85 on quality & level. when stellite scan it, no programs found. Why is that?. Because I am not able to download channels,the parental lock is not available. I am not sure what to do. Any suggestions? This is since 2 weeks..
tnx
Username: Onlyali
Post Number: 14
tht bin might not be for fortec, try to get it from www.dsstester.co*m
Username: Mc_sunny
Post Number: 12
so wut u guys think which reciever will be next with the fix ??????
Username: Zunna
Post Number: 9
hi guyz..i have pansat 3000 dis guy said dis won't be working now..and i have to give $150 to get a yellow card for the reciever is dis true...will there be a fix for it soon??
Username: Zunna
Post Number: 10
anyone??
Username: Bazuka2020
Post Number: 18
Dont waste money on the card receiver fix is on the way just be patient
Username: Zunna
Post Number: 11
thx abdul!
Username: Moe948
Post Number: 7
sunny, the next reciever with fix is likely going to be Captiveworks or cootsat. Pansat and fortec probably won't get a reciever in the next coming 7 days because Blacklist is out to Germany right now but he's coming back tomorrow. I seriously can't say how long it would take to code the bin, but I would estimate about that it will take maybe a week or so.
Username: Lklives
Post Number: 3103
FYI....This cmd 7 ECM has been seen and logged in the data stream for the past 5 months as stated by a personal friend of mine who is a coder...Viewsat coders have posted that they started working on the crack for it, OVER 1 year ago!...This was NO easy nut to crack!
Viewsat coders have stated, they are NOW going on vacation for a couple weeks and will not help anybody else until at least, when their vacation is over!....so I wouldn't expect to see too much too soon!
Username: Wk66
Zunna,for $150.00 you can get yourself new
viewsat receiver.Forget that card.The Pansat processor is quite slow and sooner rather than later you're going to loose it for ever.
Username: Maxfun
Toronto, ON
David Raja,
I downloaded the 275T files from dsstester.co*m. That did not help my receiver as the knight rider lighs was not going away. I had to go to another website to download 275T version and get the receiver going. After that, I went into factory setting, entered the passwd and pressed ok. Looks like it deleted the factory setting?. If so, Is there a recovery?
