Russian channels
Username: Olga
Hello!
Anybody knows abour russian channels. how to get them back. my mom drives me crazy...
Username: Leew
Ketchikan, ALASKA
Post Number: 412
You can get it from Nimiq 2(82.0°W),NTV,RTVi
Username: Leew
Ketchikan, ALASKA
Post Number: 413
Check this :
http://www.lyng*sat.com/packages/expressvu2.html
dont forget to remove *..
Username: Olga
Thanks, Mike for information. Is it free channels? I have 2 dishes now----1)Echo7/119 SW--- 2)Echo3/61.5 S. I added Nimiq to dish (1). I can see Russian channels at list. But screen is black... What about dishes directions or changing NiagraVision2 or something more...
Username: Leew
Ketchikan, ALASKA
Post Number: 414
Hi Olga. I got ORT1 and RTR from DirecTv,for 20$.And for all other "testing stuff" I use it motor dish with universal LNB. You can try to realign yor dish2 from Echo3/61.5 to Nimiq2/82.0,but don't forget to make some mark (maybe you have to go back in some other day).it's very simple work,just move dish clockwise and elevation up 5-10mm.Do it slowly and somebody have to watch tv or meter that is all.(don't worry Nimiq got very strong signal, you cannot miss it.)
Good luck.
Username: Leew
Ketchikan, ALASKA
Post Number: 415
I forgot: my FTA is Pansat 3500S and BIN for now # 351, from black list. I have no DN at all. but for "Beverly" still good.
Username: Mizaheer75
Mississauga, ON Canada
Hi Mike W Lee,
Just wanted to double check, for Nimiq do i have to download new channel list from channel master or just do blind scan??.....Your help would be appreciated.
Username: Leew
Ketchikan, ALASKA
Post Number: 416
Hello imran zaheer .I do blind scan, then I used channel master to remove some trash channels or make some favorites.By this way you will get yours channel list.
