Problems loading ecko3 , echo 7 and echo 8.3
Username: Smarcus76
hello there..
i have a panset2500A, and i was missing chanels so then i decided to click the option(factory settings) but now, my box only acept me to view channels that are listed in echo 8.6, if i do a blind scan onn echo 7 or even echo3 My receiver keeps booting on me during the search and do not allow me to add all the echos to my chanel list. is there anything i am doing wrong?
please help..
marcus
Username: Wild_willie
Post Number: 15
when you do a factory reset, you lose your channel list. You will have to load it back into your reciever. Your channel list will allow you to pick up channels that may not have been picked up durring your sat scan due to weaker signals.
Username: Smarcus76
i can load echo 3, echo 8.6 and echo 7 but they are all loading the same chanells.. every time i blind scan echo 3 echo 7 and echo 8.6 the chanels are the same in every single one of them.what am i doing wrong??
Username: Smarcus76
i keep getting the same exact channels on ecko 3 ecko 7 and ecko 8.6... what am i doing wrong??
please help
Username: Lklives
Post Number: 3020
your dish is ONLY aimed at 1 satellite...
Username: Holyman
How many LNB do you run?
Sounds like one. Let me stop there before I PUT MY FOOT IN MY MOUTH!
I will go on after you reply.
Username: Dallastx
Post Number: 7
any one have new bin file or keys if you guys do please can you post here
thanks
james
