Temp Fix For PPV
Username: F_t_a_is_back
Post Number: 45
Go to the VOD channels to watch PPV...I'm sure charlie is monitoring us and these will be down soon...enjoy what you have for now until fix comes out...BL knows about problem and is on it...no time table set for new bin but is doable...just waiting to see what else dick is going to do...
FTA
Username: Doubledj
i am running the 274 clone safe bin on two boxes 2500a an 2700a both are blacked out on all channels an trying to roll even with auto tp and auto roll off ive rescanned but no blind scan just regular sat scan....sats renamed but i cant see if theirs new keys all i could read was to use the same keys for 00 an 01 starting key numbers e8 70 b0 ....etc please help ill settle for basic channels
Username: British
Post Number: 30
N 0101 00:
E8 70 B0 0A 8E 0A 3D C5
F3 59 C3 5F 1A DA 19 5C
N 0101 01: (active)
71 9C 60 71 04 C1 39 AE
88 FF F0 5E D2 4C F3 FC
those are the current keys, enter the keys manually, and before to go out from cas screen, and turn off DN autoroll off. right now arent working ppv's and xx. no scan needed.
Post Number: 46
dj horn...you should not hijack threads...there is no need to rename sats...
01: (active)
71 9C 60 71 04 C1 39 AE 88 FF F0 5E D2 4C F3 FC
Post Number: 47
BK...use the VOD channels...PPV are all there...
FTA
Username: Doubledj
very sorry fta just didnt wanna start a new post an where im using msn tv i ccant view all the post where there is ovcer 40 replys so very sorry
Post Number: 49
No problem...just enter the keys
FTA
Username: Username999
HOw do we do above VOD thing in Viewsat Xtreme?
Post Number: 50
User...when you scan the sats, the VOD (Video ON Demand) start on channel 9926...there are only nine of them but atleast we have some until BL has a fix...
FTA
tHANKS FtaIsBack. Any ideas about ultim, ten etc?
Post Number: 52
No adult channels till BL has a fix for what charlie is doing...he will have a fix...be patient...did you get the VOD channels?
FTA
Post Number: 7
Yes FTA. It did work. Thanks so much!
Post Number: 53
All we can do is wait for now...the sky is not falling yet...
FTA
Username: Vipsang
Does anybody can tell me how can I find or setup VOD channel and exactly what does vod stands for? I have only one dish pointing towards 61.5
Username: Miguel03
Tucson
Hey Vip, VOD stands for Video on Demand and you need to have your satellite torwards 110 and 119. You can see them in channel 9925-9934. You can go to this website to look at the channel lisiting available http://ekb.dbstalk.com/dishlist.htm.
