Satellite gone
Username: Ttope
Friends can somebody post new keys, I was using keys starting from 71 and 88. I have fORTEC STAR CLaSSIC NA and it take 4 set of keys.
Username: Lklives
Post Number: 2908
Posted everywhere here...LOOK...help yourself before U expect others to help U!
Username: Arabic
Windsor, Ontario Canada
Please I want Help...
I have been watching the Arabic Channels on Dish Network
(DN) for years on Satellite E9 at 121.
Today May 31, 2006 at 2:30 Estern Time, all Arabic
Channels lost Signal..except one its name is "Abu Dabhi".
It is unusual, becuase key change did not affect the
signal before.
All what I am geting now is "No Signal"...before when the
key changes the message was :Scrambled or Bad Channel".
Please Help, I am using Fortec Sat Ultra.
Username: Lklives
Post Number: 2922
More than likely DN moved it to another TP or satellite...use your head and do another scan instead of whining and doing nothing!
Username: Hamidtheshah
Toronto, Ontario Canada
my receiver just says free to air on it !!i dont know what's the name
Username: Chotia_rround
wat a chotia guys are you....itzz down down not gonna work dumboozzzz
my receiver just says free to air on it !!!! i don't know what tpye??? can anyone help??
Username: Smalltiger
Post Number: 15
Key (01) :E8 70 B0 0A 8E 0A 3D C5
Key (02) :F3 59 C3 5F 1A DA 19 5C
Key (03) :71 9C 60 71 04 C1 39 AE
Key (04) :88 FF F0 5E D2 4C F3 FC
I have one ,from menu then use the right arrow select channel then scroll down to code ,the code is 1001 the keys open then find nagra.If you have the latest bin, you will see 00,01,02,03
