SatCruiser101Plus+
Username: Nalbouz
Post Number: 27
Can any one tel me how to enter keys on satcruiser101plus+
Thanks
Username: Lklives
Post Number: 2843
To enter the key for Satcruiser, go from menue-> installation->type 0000 when ask you for password--> code-->N-code--> on that screen you will chose the key you want to change the entry for it and it will work like this:
for DN
0101 00 E8 70 B0 0A 8E 0A 3D C5
0101 01 F3 59 C3 5F 1A DA 19 5C
0101 02 71 9C 60 71 04 C1 39 AE
0101 03 88 FF F0 5E D2 4C F3 FC
Username: Starcruiser
If you need to enter the keys manually, you must first disable the DN autoroll feature in (menu, system setup).
New software for R3X is available on www.skyfiles.net the software for R3R will be available soon
To enter the keys manualy
menu, installation, edit key, select N (for Nagra) the correct key will be highlighted, press OK the use the volume key on your remote to point to the keys field then press OK. Enter the first 8 key combination then press MENU, go down to the second part of the key and do the same, enter the second 8 key combination and press menu. You may need to go up channel or down channel for the TV picture to pop up.
Username: Nalbouz
Post Number: 28
Thank you LK and Baz, i have already auotroll and
the bin file i have is the one of 10May2006_r3r_8m_key.bin
and the firmware is r3rdamfxw.20080F492
thanks again for your help
