I have dish network with 119 and 148 setup. When I change from a 148 channel to a 119 channel I have to turn the receiver off then on again before I get a picture. Does anyone know why?
Some of the BIN files have issues, so use the most current one, if in doubt, like the 2.76e_EU(N) which is the newest one as far as I know. Make sure that the DISEQC settings are right, but sometimes they are also defective. If you use a SW21 switch instead, then the newer bins are written for them, and they refer to them as Legacy switches....hope this helps, but if you are using a DISEQC switch, I would substitute it first, or try it close to the receiver, because it could be a problematic coax cable or connector as well, not getting the data to the switch from the receiver.
