Pansat 2500 A 119 Channels
Username: Michaloui
Does anyone knows how can i get the 119 channels i only get the 110 channels
Username: The_wank_artist
Post Number: 548
add another LNB.
You need one LNB per satellite.
(the LNB is the thing on the end of the arm sticking out from your dish)
Username: Michaloui
i have two lnbs but i dont get signal for 119
Post Number: 550
Are you hooked up to a diseqc switch?
Are the ports selected correctly in the installation menu?
Have you checked your connections, cables, etc on that line?
If you switch the cables with the 110 lnb and 119 lnb do you now have the same problem but with 110 now? Maybe a bad LNB?
Username: Michaloui
i connected the 110 straigth to the pansat and then the 119 but only the 110 are working i switch the lnbs and still i cannot even see the channel list when i connect the 119 but i can watch the 110
Username: Michaloui
i switched the wires as well i still have the same problem
Username: Lklives
Post Number: 2832
mike...then U have NO problem...cause there is NO logical explanation!...U switched LNB's, cables, receiver settings etc...only thing left is U never had 119 LNB aligned nor watched it...or U have a BAD receiver!
Username: Michaloui
i have another satelite to get the echo 61.5 and this is working as well i dont now what is going on
Username: Michaloui
Post Number: 7
i could watch both of them before one week then i reset the settings and i upload the bin file and the channel list but this time the 119 are not working and when i connect them i cannot even see the channel list
Username: Wnyzfinest
Post Number: 28
remember mike you need a DISH PRO DUAL LNB OVER A DISH 500 if your getting 61.5 Sounds like a Dish 300
Username: Lklives
Post Number: 2839
U mean a DP TWIN LNB...or 2 Dual or 2 single LNB's for the 110-119 birds..
Username: Michaloui
Post Number: 10
I have 2 lnbs one for the 119 and one for the 110
Username: Michaloui
Post Number: 11
i have a different dish for the 61.5
Username: Michaloui
Post Number: 12
i have a different dish for the 61.5 and those are working
