Keymaster or keyfinder or what?
Username: Neurosis
Post Number: 8
I keep finding the keys for N2 in different threads and they are different then the keys I get from keymaster. When I run the program I get the:
Updated: Thursday, May 25 2006 at 7:18 AM version, the keys on it don't work, and they are different then the latest ones here.
So I guess my question is which program is the one I should try and find?
Username: The_wank_artist
Post Number: 528
Those are the correct keys that Keymaster is giving you, it just listing the inactive and active keys.
SOMETIMES you don't have to use the inactive keys, on some receivers. Those are the first set Keymaster lists.
The active keys are the important ones. I've always used Keymaster, but I guess it's a personal preference.
Username: Neurosis
Post Number: 10
not to mention it has a cool startup wav.
Post Number: 531
'Initiating start up sequence.'
If I'm not mistaken, it's from Austin Powers.
Username: Pirate_pete
Post Number: 31
Were did you get key master?
Username: Califirnia
Post Number: 9
Dsstester or future-fta
add dot com at the back
