PPV movies and ppv sports
Username: Buddho81
I have an Advance SAT FTA receiver...This has been by far the best receiver I have ever had. It picks up all the new keys automatically and keeps my box up and running. I've had this for almost 3 months and have never had to change anything...just yesterday since i was missing about 3 or 4 channels that I like to watch I did factory default on the box...rescanned all the satellites again and i am having trouble getting all the PPV channels...
I was getting all the PPV channels before just not now after restoring to factory default...
I do get all the channels from 121 and a few from 119 and 110...but still missing a lot of channels...
my setup super dish
121 -- lnb1 -- 10750
119 -- lnb2 -- 11250
110 -- lnb3 -- 11250
Any suggestions will be appreciated!
Thanks again!
Username: Evadelparaiso
Puerto Rico
Post Number: 313
MANUAL key change the tp for your ppv and sport channels. check this site for the tp information.
www.lyng***sat.com
Username: Ousu
Hello
I have a panasat 2700a
How do I get my PPV back
I lost them a Month ago
Thnks
Username: Babakhan
Post Number: 121
Hey Ousu u need to do Factroy reset...Go to Your Menu and do that,after that do this step by step
1. From the MAIN MENU: selecting INSTALLATION then Antenna setup Option.
These are my dish set up and DiSeqC multi switch configuration;
DiSeqC #1 SuperDish Echo9-IA 13 Dishnet 121
DiSeqC #2 Echo8.6/Ku 110W,
DiSeqC #3 Echo7/Ku at 119W
Satellite: ECHO 9(121) same as dish 105
Lnb type-Standard
Lo freq-10750
22khz-OFF
DiseqC- #1
Skew: O
TP: leave it as is
Positioner-Disable.
Satellite: ECHO 6,8(110)
Lnb type-Standard
Lo freq-11250
22khz-OFF
DiseqC-#2
Skew: O
TP: leave it as is
Positioner-Disable.
Satellite: ECHO 7(119)
Lnb type-Standard
Lo freq-11250
22khz-OFF
DiseqC-#3
Skew: O
TP: leave it as is
Positioner-Disable.
2.Check the signal and Quality level highest as you can (adjust the dish slightly to improve the signal strength).
If you get no quality level on transponders, try others before giving up, because not all TPs are transmitting,
if nesscery Re-aim your dish still not getting any quality signal
3. Press the Exit button, press OK to save setting, the back to the Main Menu
4. Go back to the Installation Menu
5. Goto SATELLITE SCAN or BLIND SCAN, press OK, select the satellite to scan.
you have to scan all the satellites have, once it complete, you should be able to watching TV
Username: Ousu
Hello
Thank you baba khan
I did what you listed
But I only get signal at the disqC at #2
on all three Echos.
#1 and #3 donnot work
I am only getting the 121
the 110 and 119 not coming
Many channels are avlbl
but no PPV or HBO Hallmark etc..
any help
Many thanks in advance
