Pansat 2500 receiver remote sensor
Username: Nitr0uzv
The remote control sensor on the reciever doesnt seem to always want to work. If I power off the reciever from the back and turn it on it will work for a few seconds then it stops working. Any ideas? Would a reflash help?
Username: Evadelparaiso
Puerto Rico
Post Number: 395
1.if your remote has a F botton then turn of the receiver turn it back on then press the F bottom first.
if your remote has no F botton then repet the same proseger then press the EPG botton
if this does not work repet the same proseger insted of pressing the EPG ppress the power botten with one finger , and press all the other bottons simotaneously for 10 seconds then try it
2. Check the battery contact
3. Check the eye.
