New keys?
Username: Momenali
Post Number: 27
did the keys just changed Now..cuz iam not getting anything..i own a pansat 2700
Username: Vong86
does anyone have the new keys please i need help
Username: Sharda
does anyone have the new keys for fortecstar
life time ultra
Username: Spring20003
any one have the key plzzzzzzzzzzz
Username: Lucia
Post Number: 12
15 FD 84 7F A4 D1 CF E9
01:
1C E9 58 70 2D 79 42 D9
thanks to sam_springfield
Username: 5abi
those keys dont work, lucia read the damn post, he replied b4 u posted with the codes dont work
thanx lucia for tha key its working for me
Username: Bertoro
Toronto, Ontario Canada
Post Number: 34
they do work bob...thanks gracias lucia
Username: Qasim
Montreal, QC Canada
how u program the receiver can some one tell me
Username: Anmol
Selma, Ca Usa
rex-1 key?
Username: Hicham
thanks 4 the key it s working 4 me
un gros merci pour tout le monde..
Username: Picass0
can some one tell me how to entre the new keys step by step Iam from montreal canada and have dish fortec network
Username: Shukla
Melrose Pk, IL USA
i have pansat 2700A can u please quide me what is the procedure to enter the keys
Username: Gunaa
Post Number: 7
Hi Lucia!! I have pansat 2500 clone the key up there is not working for me please help!!!
Username: Sharda
thanx lucia for tha key its working great
thank lottttttt
Username: Picass0
What is the ID provider do I have to chage this ...?
Username: Picass0
and after I entered the key do i have the SCAN the chanelles ? (echo 7 and echo 8.6)
Username: Qasim
Montreal, QC Canada
can some one tell me how to entre the new keys step by step Iam from montreal canada and have dish fortec network my email is world_prince2001@hotmail.com
Username: Shamiadd
Post Number: 13
hey everyone...i tired the new keys for
fortec ultr and it works fine
15 FD 84 7F A4 D1 CF E9 (00)
1C E9 58 70 2D 79 42 D9 (01)
both those keyz should keyed under nagara vison 2
k :-) t/c allll :-) BYE:-) thanks for the help!
Username: Sharmag
my password "0000" is not working can someone please tell me how to fix that to get into Nagara vision to change the keys? Please help me out if someone knows how to get into the system to change the password?
thanks
Sun
Username: Letmeon
Post Number: 17
try 1668 or 1010
Username: Picass0
i use also 1668 and it works fine for me
Username: Mahmood
Toronto, ON Canada
can anybody send me the new keys i mean 4 lines
Username: Mahmood
Toronto, ON Canada
please help me. send the new keys the two line keys are not fit for my system, i need four line keys
Username: Vndpatel
Post Number: 24
new keys for pansat 2700a
Dish Network:
N 0101 00:
AE F1 0F 87 F9 58 E1 55 3A E4 8B AE ED DB BB DF
N 0101 01:
15 FD 84 7F A4 D1 CF E9 1C E9 58 70 2D 79 42 D9
Username: Mahmood
Toronto, ON Canada
I tried these keys but these are old. i need new keys for fortech star
Username: The_wank_artist
Post Number: 309
mahmood,
they are not old. You are not entering them correctly.
Username: Qasim
Montreal, QC Canada
Post Number: 8
fortecstar i want to know how to enter the new key plz some one is kind enough of to tell me how to plz
Username: Shamiadd
Post Number: 14
Username: Salam
Post Number: 11
How to enter key for Pansat 2700a
Press menu button on your remote:
#1 Go to parental control...
#2 Go down to "second pin" option & enter 0000
#3 Then go to nagravision and select it by pressing ok button on your remote...
#4 In Nagravision window you should be in the box that is Entitled "Provider ID"...scroll to the right (press right arrow button on remote) until it switches to Dishnetwork (00 01)
#5 Now In Nagravision window go down (press down arrow on remote) to the box that contains "00" entitled "Key Number"
#6 While in the box (highlighted "Key Number") that contains "00", scroll to the right until you see nagravision 2 at the top left of your screen
#7 While in Nagravision2 you should still be in "Key Number" box and the number in that same box should be "00"...this is for Key 00
#8 Scroll down (press down arrow on remote) to key data and enter the new supplied key for 00 (within this site is the key change for Nagravision2)..take note on how to enter letters in the lower portion of the screen (ex. letter E=FAV button on remote)
#9 Once key is edited select OK button on your remote (OK-STORE confirmation blinks twice in lower right of screen)
#10 go back to the "00" box and move one click to the right which should take you to "01"..this is to edit the "01" key
#11 Follow Steps 8 & 9 above (this time enter key data for key 01 instead of 00)
#12 Click exit and click ok or yes to save changes then exit all the way out and you should be watching tv
Username: Mahmood
Toronto, ON Canada
Great these are working sorry the first two lines are same but later two are not.
wonderful it is working
Key0 AE F1 0F 87 F9 58 E1 55
key1 3A E4 8B AE ED DB BB DF
Key2 15 FD 84 7F A4 D1 CF E9
key3 1C E9 58 70 2D 79 42 D9
Username: Qasim
Montreal, QC Canada
Post Number: 9
yo let me how to enter the key step by step any one plz i have fortecstar
Post Number: 311
You are doing something wrong then Qasim.
00:
01:
Username: Qasim
Montreal, QC Canada
Post Number: 10
where i go to enter these keys i have no idea that the first time
Username: 5abi
thnx so much i needed the 4 line version cuz either i just got confused thnx so much all u guys
Post Number: 314
Go to your receiver Qasim, you need to enter them there.
Username: Qasim
Montreal, QC Canada
Post Number: 11
but the steps that is show u not the same i uderstand that i have to enter there but how i get to that step and can u give the site or send me the Nagravision2 plz and thankx for the help so far
Post Number: 317
I answered you in one of the many other posts you had. Go find it...
Username: Qasim
Montreal, QC Canada
Post Number: 12
ok thankx
Username: Rohit123
Toronro, Ontario Canada
can i plz get the keys......thank you...
Post Number: 321
Lucky number seven Rohit.
Up from your post that is...
Username: Learningsats
Post Number: 13
Does anyone have the keys for Viewsat Platinum?
Post Number: 322
Doh!!!
Username: Qasim
Montreal, QC Canada
Post Number: 13
i can't find ur posting can u give me the steps how i can get Nagravision2 plz
Username: Sakapfet
Post Number: 7
nice keys work good
Post Number: 325
How to change the NAGRA2 Key codes
(for Fortec Lifetime Ultra only)
1- Press Menu button on your remote control
2- Press right arrow key 2 times Channel Edit
3- Press down arrow key button 2 times, press OK (Code) enter 1010
4- Press the down arrow key to Set Default Key, click OK
5- Press the up arrow key to Nagravision click OK
6- On your top left you should see Nagravision-1...if not, then you've got the wrong BIN version.
7- Press right arrow key until you see Dish Network on top
8- Press the down arrow key once to Key Number
9- Press right arrow key 2 times the from Key Number 00 - 01 - 00
( Now take notice that on your top left you should see Nagravision-2 now )
10- Then press DOWN button key to change the keys manually on Key Number 00
11- Enter new Keycode, do the same procedure to enter the the keys on Key Number 01
Note:
Satellite Providers changes the stream key codes unpredictably,
(Note: remote control key letters equivalent)
A = Sat, B = i, C = Tv/Radio, D = Pause, E = Audio (speaker), F = EPG
12- Check and make sure that you got all the keys....Press OK to store (save)
13- Press EXIT key 3 times to exit to the channels.
Note:
If you accidentally lock the KEYCODE (OFF) use this default password 1668
Username: Picass0
Post Number: 7
-Menu
-parental control
-go to seconde pin 1668
-scroll down NARGAVISION
-set to nargavision 2
-entre pin
-then press OK
-CANCEL CANCEl CANCEL
Username: Qasim
Montreal, QC Canada
Post Number: 15
thankx i got it
Username: Rohit123
Mr. tyler i have fortec star life time ultra how do i chnge keys for that please can u tell me..
Username: Rohit123
can sum 1 plz tell me the keys for fortec star
Username: Rolla
I have pansat 2700E and these keys work great
N 0101 01:
Enjoy
Username: Rolla
N 0101 00:
Works too
Enjoy
Username: Rohit123
help me plz....keys for fortec star
Post Number: 330
if you have two lines, use
Username: Rohit123
i used that but its not working coz i dont have nagravision 2 nd i tried getting it am not getting it....
Post Number: 331
Rohit,
The keys are the same for all receivers for N0101.
Username: Whatzzzuppp
Montreal, Quebec Canada
Post Number: 47
hi there
i have fortecstar, i don't know how to enter the keys, bec ause i don't have the nagra i really need help in here anybody plzzzzzzzzzzzzzzzzzzzz
how can i fix this thing plzzzzzz help
Username: Rohit123
Post Number: 7
but i dun have nagraversion 2..how do i get dat...i did the procedure how it is to be done but am still not gettin it...
Username: Wakenbake
Post Number: 101
when is the last time you had t.v. on this fortec
Username: Rohit123
Post Number: 8
in the noon...so can u plz tell me how to get nagraversion1 nd2 both i need it or else will die.........
Username: Darek
THANX FOR THE CODES GUYS AND GALS GOT IT GOING RIGHT AWAY!!!!!!!!!!
Username: Wakenbake
Post Number: 102
nag1 is dead
you only have nag2
R.I.P.
Username: Rohit123
Post Number: 9
k but i dun have nag 2 also i just have nag....
Username: British
Post Number: 24
Dish Network:
KEY86: AE F1 0F 87 F9 58 E1 55 3A E4 8B AE ED DB BB DF
KEY96: 15 FD 84 7F A4 D1 CF E9 1C E9 58 70 2D 79 42 D9 (Active)
Username: British
Post Number: 25
rohit you must use bin 104t for fortec or 273t for clones. those are auto roll, if you dont understand. go to newbie threads and start to read. you will find your answers
Username: Wakenbake
Post Number: 103
ro,
only uderstand english
Username: Rohit123
Post Number: 10
thnx BRITISH KNIGTH...but how do i go to the newbie threads its not openin...
Post Number: 332
Rohit,
Note:
Note:
Username: Rohit123
Post Number: 11
dude i did dat..its not workin still coz i am not gettin nag 1 on the left i just get nag nd its not yet workin....
Username: Kido1975
anybody got keys for bev 82? if you got it thanks.
Username: British
Post Number: 26
go to system info and tell us what it said.
Username: Rohit123
Post Number: 12
k the sys info is
X-8537
API:2.55c-EU
Boot ver: 6.0
24. sept.2005
Future. FTA
Username: Wakenbake
Post Number: 105
rohit what is nag nd
Username: Wakenbake
Post Number: 106
baby needs a new bottle
Post Number: 333
wake, that line was GOLDEN!!!!
Username: Rohit123
Post Number: 13
listen i dunno muchr askin me am tellin u aiite....so help me if u can if ucant then its ok...
Post Number: 334
Rohit, what satellites are you trying to pick up?
110 and 119?
Username: Wakenbake
Post Number: 107
ro,
you are running a old bin
update
Username: Rohit123
Post Number: 14
no am tryin to pik up 119 nd 61.5...
Username: Wakenbake
Post Number: 109
ro,
go back to future -fta and get a new bin
Username: Rohit123
Post Number: 15
ok thnx....
Username: Nrogers
00:
01:
thanks to sam_springfield and Lucia... Thanx a lot for info... Its working for me .
Post Number: 48
hi
anybody please can help me i do not have nagra anyone please help 2 enter the keys
Username: Sakapfet
Post Number: 8
take viagra if you dont have nagra
Username: Nrogers
Just gone blank ...again.. new keys info ??????
Post Number: 353
N 0101 00:
E8 70 B0 0A 8E 0A 3D C5 <- New
F3 59 C3 5F 1A DA 19 5C <- New
N 0101 01:
Username: Mahmood
Toronto, ON Canada
these are not working. can anybody tell what are the new keys for today. may 18th evening
Username: Bertoro
Post Number: 35
they are good working keys, please verify your settings, and stop asking again...the keys given by tyler work!!
Username: Khurramppmc
Mahmood
These are the keys for fortec star
00:E8 70 B0 0A 8E 0A 3D C5
01:F3 59 C3 5F 1A DA 19 5C
02:15 FD 84 7F A4 D1 CF E9
03: 1C E9 58 70 2D 79 42 D9
Username: Nrogers
Yes, These are active keys. working for me as well. Thanx to Tyler Durden for quick posting to support all of us.
Mehmood, you may need to check your inputs of keys.. double check every single entry.
Username: R1010
thanks to all of you for posting the new keys
Username: Obl
Toronto, On Canada
can any one post keys for pansat 2500 plz
Username: Micsgrandy1
Hickory, Nc Usa
need new keys for nag 2 for panasat 2500a. sat 110 and 119 . new fortec keys wont work help
Username: Lucia
Post Number: 13
those keys don't work!
Username: Evadelparaiso
Puerto Rico
Post Number: 324
Lucia the new keys that post Tyler today are working fine. N 0101 00:
N 0101 01:
check you receiver
Username: Yarda_666
khurram
\your 02 and 03 worked for the 2700 as 00 and 01 this morning.
are your 00 and 01 correct for now??
Username: Lucia
Post Number: 17
do you think i have to do a new scan? because i've put them like 5 times now and they still don't work
Puerto Rico
Post Number: 325
These keys are the same for all receivers, if you have only two rows put the new active keys.
Username: Yarda_666
dish network
Username: Jdog
what keys are working for dishnet for a panset 2500e?
Post Number: 359
read post at 8:45
Username: Zmkn2000
Mississauga, On Canada
can someone please tell me how to work the ARIZA 700 receiver? the keys you guys are saying are not working. i have tried all. even nagra2. pls give me some instructions on where to go in menu and what to enter as all i knew was to go to parental control, nagra 2 and do the keys..thanks
Username: Obl
Toronto, On Canada
keys which worked for me on Pansat 2500A are
E8 70 B0 0A 8E 0A 3D C5 (00)
F3 59 C3 5F 1A DA 19 5C (01)
Post Number: 365
LK:Posted on Thursday, May 04, 2006 - 08:14 pm:
Coo*lsat: KEY Line 10 and 11 are for Idea Key 0 and Line 20 and 21 are for Idea Key 1
Pansat: key 00 for Idea Key 0 and Key 01 for Idea key 1
Viewsat: line 08 and 09 for Idea Key 0 and lines 88 and 89 for Idea key 1
For Receivers with only two Key Lines, Enter Active Idea Key into 00 and 01
https://www.ecoustics.com/electronics/forum/home-video/223313.html
Post Number: 368
nargis naqvi;
"also, i tried going to installation. the quality is at 0% and level at
52%. does that make a difference..?"
This makes all the difference in the world. Your dish is not aligned properly.
You'll need to get both your quality and level up to better numbers.
Get the signal a little stronger buy tilting the dish up/down. Once that's done tighten up the bolts and move on to the Quality by moving the dish left and right.
First try get some signal on it and then slowly move positions.
Keep in mind that sometimes movements are not picked up by the receiver instantly. It's best to move L or R, wait a couple seconds, check the signal. Then move again, wait a couple seconds. Once you have the quality at it's highest point, tighten the bolts and go watch tv.
Username: Zmkn2000
thank you for the answers. t.v. working fine.
Username: Dooggy498
i have fortec classic Na do some one have the new key ? plzz
Username: Loner
Need new code my system went blank. need to know what key number goes in front of each line Ex;
?:E8 70 B0 0A 8E 0A 3D C5
?:F3 59 C3 5F 1A DA 19 5C
?:15 FD 84 7F A4 D1 CF E9
?:1C E9 58 70 2D 79 42 D9
for a viewsat (dish)
Puerto Rico
Post Number: 365
Posted by LK
