Intelsat 805
Username: Hnic_men
Post Number: 97
hey guys i live in toronto and was wondering if i can get this sat Intelsat 805, if i can what size of dish and lnb do i need to catch it. thanks
Username: Evadelparaiso
Puerto Rico
Post Number: 314
From Toronto Canada: The first picture you can see the dish size do you need install if you live in Toronto, the second picture do you can see the coverage of the Intel Sat Cband
Satellite
Longitude (0° to +360°)
58
Location
N Lat (+90° to -90°)
43.7
W Lon (0° to +360°)
79.42
Antenna Pointing:
Geografic:
150.391733
Elevation:
35.229703
UploadUpload
Username: Hnic_men
Post Number: 99
ok i check out this satilite on lynsat their are 2 colour codes digital clear and digital encrypted the channel i want to get is sportsmax which is digital clear, what type of lnb do i need to use?
