Hey Tyler
Username: Tritip
Post Number: 19
Thanks for the response Tyler. One more thing. For the viewsat 2000 Xtreme I noticed the DBPSW_V1072_XTREME bin file and also the DBPSW_060510A_XTREME file. What is the difference between these two files and do they both get loaded to the receiver the same way?
Username: The_wank_artist
Post Number: 302
One is a bin and the other is a patch. the 060510 is actually one of three patches, from the 8th, 9th and 10. Each patch rolls the previous patch into the next so you actually get all the fixes in one, at least that's what it looks like.
VS2000 version 060510A
- Full channel name bug fixed :
- EPG menu changed :
1 hour display per page
Some color changed : detail event info and time
- Satellite name display bug fixed on Antenna Settings menu.
- Default LNB freq changed into 11250 for Echostar and Nimiq.
