How to setup directv Phase 2 plus dish to receive 110 and 119
Username: Argeelh
Hi everyone,
I'm hoping that someone can help me in the installation of Directv Phase 2 plus "the Dish with 3 LNB's Labled 101, 110 and 119 from right to left"
I have read the instructions by LK for Phase 3 and I tried to set it up that way but I can only get 119. This dish has 5 Coax coming out of the LNB's and connected to Disque in the back of the dish, and has 3 coax out . I have Pansat 3500S with the latest BIN. One last thing, my ultimate goal is to connect my other Dishnet "61.5" and combine the 61.5, 110, 119 together. I tried connecting the 119 and the 61.5 through Discqu, but it didn't work.
Any help is appreciated
Username: Lklives
Post Number: 2533
That is a Phase 3 dish...it sucks...impossible/extremely difficult to align...put it in the garbage!
Username: Argeelh
LK, Are you saying I can not get both satellites easily.
Is ther a way though to get anything besides 119 or 110 without too much engineering
Thanks again for your help
Username: Lklives
Post Number: 2538
If U read my post it says it all..NOT easily!...U have to add LNB's to get 110 and 119..much easier to get a single LNB round DTV dish and make a poormans dish for the 110-119..
Username: Argeelh
LK, Thanks for the info, but the question I have, is it possible to do what you described above with the Phase III. I guess I'm trying to take an advantage of what I have? Would your other post apply in this case" for both 110 and 119". For example If I align the dish to 101 "Assuming mid LNB is 101 instead of 110" can I get the 110 and 119 on the outer two?
Thanks again LK
Username: Lklives
Post Number: 2545
Didn't U read this...u will get 91 and 110...and middle LNB is useless!
The Phase III oval dish (FAQ)
All about the Phase 3 dish
(made for DTV, has 3 LNBs in same enclosure and built in multiswitch.)
YES, you CAN use this for your FTA setup to get 91 and 110 !
Advantages
1. You can add 2 LNBs and get 82 and 119 too on same dish.
2. Cheap or free from your DTV system.
3. Use only one wire and get 2 sats.
4. If u add 82 and 119, you'll use 3 ports on your diseq switch.. perfect to hook up an additonal bigger dish and a linear LNB and get birds like Intelsat 5 (T5) on your diseq empty port.
Connection
1. You need only 1 coax cable per receiver connected to the Phaze 3 dish, which is an advantage.
2. It doesnt matter which of the 4 ports you connect to. All 4 are the same in functionality. Your receiver will use the built in multiswitch to select one of the 3 sats. It does that via voltage change and 22khz tone signalling.
What this dish is for and how it was meant to work
1. This dish is for DirectTV. Was made to get the 101, 110 and 119 DTV sats.
2. Looking from behind the dish, the LNB are used like so:
.......left lnb = 119 sat
..middle lnb = 110 sat
.....right lnb = 101 sat
3. The multiswitch inside uses 22khz tone that is sent by your receiver to switch between 2 sats (just like any other 22khz switch). You'll have to set that up in your Pansat receiver.
4. 2 sats?? Yes! The multiswitch inside also serves as a combiner to combine signal from 110 and 119. So the 22khz will switch between the signal of 110 and 119 combined and the signal of 101
How the built in combiner works
1. The combiner takes TPs 2, 4, 6, 8, 10, 12, 14, 28, 30 and 32 from the middle LNB (110) and all the rest of the 32 TPs of the left LNB (119). You cannot change what TPs are combined... Covering middle LNB with foil wont work, cutting traces on the pcb wont work.
2. This is OK for DTV because DTV only has 3 TP's on DTV's 110 (28, 30 and 32) and they are different from the TPs on DTV's 119. (a tp is a frequency band on which up to 14 channels are transmitted). So combining different frequencies on the same wire, works fine. But it will affect your FTA setup.
How the built in combiner affects your pansat setup
1. You can use the Phaze 3 dish to get the 91 (bev) and the 110 (dn) satellites.
2. For that you point the dish to 101 (middle lnb), and adjust the skew. Now the left LNB picks up 110 (looking from behind the dish) and the right LNB picks up 91.
3. The combiner will combine TPs 2,4,6,8,10,12 and 14 from the 101 DTV sat with the rest of the TPs of the 110 DN sat. This means you will not be able to get TPs 2,4,6,8,10,12 and 14 from the 110 sat. but read on to see what your're missing.
What channels will i be missing on my Pansat
1. You will be missing only some local channels. (ABC,CBS..etc..), which may or may not be local to you. Thats it !
2. To see what is missing you go to lyngsat and check to see whats on TP 2,4,6,8,10,12 and 14 on DN's 110 sat.
4. You will see that ALL but 2 of these TPs are of BEAM type... which means you wouldnt have been able to get them ANYWAYS, Unless you are in the area indicated for that particular beam.
5. The 2 conus (available nationwide) tps that you'll be missing are TP 12 and TP 14. Whats on it? Only locals from Lexington, Knoxville, Jackson and Denver.
What you should be pointing it to, to get 91 and 110
Pansat setup:
Assuming you will point this dish to 101 (middle LNB to 101), you will be able to get 91 and 110 on the 2 outside LNBs WITH proper SKEW, and thats what u want do to if you gonna use it with your Pansat. The middle LNB is useless for Pansat setups on Phase 3 dish as it will be pointed to DTV's 101 sat. Also covering this lnb with anything won't help to give u back those locals that you'll be missing.
To get the azimuth and elevation for your dish, calculate it for the 101 sat. For skew see below.
DTV setup
If you set the dish like above, it will not work for DTV. If you want it to work for DTV you point it to 110 (middle lnb gets 110) and the outer will get 101 and 119.
To get the azimuth and elevation for your dish, calculate it for the 110 sat. For skew see below. Or you can use your DTV receiver, enter your zip code and it will give you all settings.
U can't use the Phase 3 dish for DTV and Pansat at the same time because you're pointing to different sats.
How to calculate and use Skew:
Skew= vertical offset (twist) in degrees from the vertical (from the 90 degrees mark on your dish)
1. Go to Satellite Nut page
2. Enter your location info.
3. Calculate skew for the 2 outter satellites on your dish (for the pansat setup on Phaze3 that would be 91 and 119)
4. Add them toghether and divide by 2
5. U get the skew number. (Disregard the minus sign if its negative)
To use SKEW:
You must ensure that the top of the mast is perfectly plum. Best thing is to use an eye round level (home depot,tools section - $3) that u put right on top of the mast. You do that BEFORE you even put the dish on the mast.
If you are on the EAST coast, skew = counter-clockwise rotation in degrees from the 90 deg mark on your phaze 3 dish. Set your dish to 90 minus the skew number
If you are on the WEST coast, skew = clockwise rotation in degrees from the 90 deg mark on your phaze 3 dish. Set dish to 90 plus the skew number
Receiver setup
No diseq switch is needed, only one wire needs to be connected to the Phase 3
91: 22khz OFF, Diseq - OFF (or ON - doesnt matter)
110: 22khz ON, Diseq - OFF (or ON - doesnt matter)
Can i also get 119 on this dish?
Yes, if you have an additional DTV or DN (circular) LNB laying around, you can strap it to the LEFT of the 3 existing LNBs (looking from behind the dish). You will now have to use a DiseqC switch to switch between the wire from the Phaze 3 and the wire from the strapped LNB.
Receiver setup with the strapped on 119 LNB
Assuming u put the wire from the Phaze 3 in port #1 and the wire from the strapped LNB in port #2, your setup will be:
91: 22 khz OFF, Diseq #1
110: 22khz ON, Diseq #1
119: 22khz OFF (or ON - doesnt matter), Diseq #2
Can i also get 82 on this dish?
Yes, if you have an additional DTV or DN (circular) LNB laying around, you can strap it to the RIGHT of the 3 existing LNBs (looking from behind the dish). You will now have to use a DiseqC switch to switch between the wire from the Phaze 3 and the wire from the strapped LNB.
Receiver setup with the strapped on 82 LNB
Assuming u put the wire from the Phaze 3 in port #1 and the wire from the strapped LNB in port #3, your setup will be:
82: 22khz OFF (or ON - doesnt matter), Diseq #3
Username: Argeelh
LK, Thanks for all the info and the post. The question that I have which you might have already answered several times.
I can not get the 110 and the 119 out of this dish by just aligning the mid LNB" which says on the back of it 110" to DTV 101?
Also are these LNB differ or are they the same as far as the makeup?
Finally do you know why I have 5 coax out going through a switch and coming out with 3?
Thank you again
Username: Lklives
Post Number: 2557
EchoStar VII
Technical Summary and Satellite Overview
EchoStar VII was launched successfully on Feb. 21, 2002. The satellite is located at 119 degrees West Longitude. The satellite is one of DISH Network's primary satellites in offering its core services and local programming.
Final Orbital Location: 119° West Longitude
Coverage: Continental U.S., Hawaii, Alaska and Puerto Rico
Launch Vehicle and Provider: Atlas IIIB by International Launch Services
Launch Location: Cape Canaveral, Florida
Spacecraft Manufacturer: Lockheed Martin Missiles and Space
Spacecraft Series: A2100AX
Launch Weight: 8,859 lbs. (4,027 kg)
Beginning Power: Greater than 13 kW
Reflector Antennas: 1 Receive (44"), 2 Transmit (108")
Transponders: 32 conus + spot beam transponders
Username: Argeelh
LK,
Thanks for the infor, but can you help me answer my previous post.
Sorry for my confusion
Regards,
Username: Lklives
Post Number: 2560
The middle LNB is useless for Pansat or FTA setups on Phase 3 dish as it will be pointed to DTV's 101 sat
What don't U understand?
Username: Argeelh
Post Number: 7
LK,
Your knowledge is greatly appreciated. I'm by no means as expert as you are. I guess my question on the Phase 3 is simple, I have 3 LNB's on this dish and what I want to know is If I have the 119 Sat currently working fine (I have aligned the dish to the middle LNB with the assumption that it is 101" with out adding any LNB's , Can I use the existing ones to get the 110? I hope this is simpler question? The dish I have has what I think is a switch on the back of the dish"is that standard?". The 101 LNB has 2 output, the 110 has one output and the 119 has also 2 output. they are all combined and at the end there are 3 coax cables coming as an output from the switch.
Can I use the switch to combine my 61.5?
If you need additional clarifications please ask and I will elaborate.
LK, you are really a extremly helpful person and I really appreciate it
Username: Lklives
Post Number: 2579
Yes there is a 22khz switch...and yes I have thrown 50 of those Dishes in the garbage..If U want some different answers then I suggest that U TEST things out yourself..as I posted U can get the dish to work with 4 satellites, if U want to spend the money and the time..
I tell people to "keep things simple"...buy do whatever U want..its your dish..
Username: David_34mark
Brklyn, Ny Usa
can some one tell me the new keys
Username: The_wank_artist
Post Number: 243
Maro,
Please post only messages in threads that are on topic. This thread here was having a very interesting technical discussion on setups.
Thanks.
