Pansat 3500 SD b70 lockup
Username: Hawk123
Hi,
New Pansat 3500 SD. loaded 145 bin, never rebooted properly. I now have b70 all the time. I've read the threads about using Null Modem cable and tried loading a 122 bin (original for this model I believe). PC says Flash Update Fail.
Using x-05bl loader v3.42 and pansat_3500s_060502_122.api.bin
Any suggestions? thx in advance...
Username: The_wank_artist
Post Number: 150
Already been asked/answered. And not that long ago. Nor in a galaxy far, far away...
https://www.ecoustics.com/electronics/forum/home-video/212301.html
Username: Hawk123
thx for replying, I failed to mention that I am working on that solution, and Im stuck on step 6. Gives me the Flash Update Fail when I follow the instructions. Im looking for next step if it doesnt work or if there is something else I can try...
Username: Lklives
Post Number: 2443
flash failed...wrong or defective cable or comport!
Username: Hawk123
thx LK, I have a null modem cable, but I had to use an adapter (female db9 to female db9) because my rs232 cable is male db9 to female db9. Pansat and PC both have male db9. Could it be the adapter? or maybe my cable is x-over instead of null modem?
Username: Lklives
Post Number: 2445
Pansat 2700/3500 use same null modem cable...pansat 2300/2500 is diff...but all look same..
Username: Johnner
Post Number: 78
Most likely you are using a strait cable like for 2300 and 2500 instead of a null cable.
You can get an adapter for strait to null or buy another null cable and try again.
