Problem with fort*c lifetime ultra
Username: Cincy_jughead
Post Number: 18
can any one help point me in wright direction
I need to know how to delet double chaneles
thanks in advance
Username: The_wank_artist
Post Number: 237
Here is a link to the manual for your receiver.
Please read it, maybe take it to the beach and work on your tan?? Pay particular attention to page 13 '5.3 How to delete channels'.
http://fortecstar.com/Estore/store/Assets/userguide/65-userguide.pdf
Post Number: 19
thanks for all your help Tyler Durden
have manual in front of me when go to delete only one channel shows up instead of 2 or3 channels
Post Number: 20
Tyler Durden
read all the time do not post a lot
most of time can find out by reading and dont have to post
Post Number: 21
Tyler
can I set defalt key and rescan to take care of problem
Post Number: 240
You could delete all channels and rescan, that would get rid of all the dup channels.
If you had a channel list installed prior to deleting the channels they will not show up the same as they used to.
As an example, my channel list has been modified using an external software program, so if I look at a channel say 100 on E*8 it says '100 Dish Info' or something like that. If I delete the channel and scan it back in it would just say 'HOME', or whatever it is.
Post Number: 22
Tyler
