Can I connect a multi switch to....
Username: Confused1234
I have a directv 4 room system and each room has HD. I want to get the DVR for the den, but I don't want to run another coax down the wall. Can I connect a multi switch to the single lead in the den from the dish and run two from the switch to each tuner on the DVR?
Username: Boyce
Post Number: 61
No, it won't work ,you will lose some channel.
