New bin file for Fortec Star
Username: Infinite
Does anybody have a new bin file for Fortec Star? Also, can anybody help me put with the instructions since I will be doing this for the first time.
Thank you for the time.
Username: The_wank_artist
Post Number: 63
bin 273T and use BL updater 1.4
It's for a pansat but works with the fortec from what I'm told.
Username: Infinite
Thanks Tyler. But where do I get this file and how do I upload to my receiver ?
Please help !!!
Post Number: 67
You'll need a loader which you can get it from any reputable fta site, except here.
Anyway, check out dsscommunity and you should be able to find it there in the file section. You have to register but I believe it's free.
There should also be instructions there to find.
check here....
http://www.dssrookie.com/forums/sitemap/f-111.html
Username: Nsreen200
Dallas, Tx
Post Number: 7
How To Manually Enter Keys for fortec star???? I have only one line on Nagravision
Post Number: 106
Nasreen,
Instead of posting in 5 different threads, why don't you read this one, get the bin discussed and load it to your Fortec? Then you won't have to manually enter them anymore.
