EPG
Username: Conti
Post Number: 23
I am getting EPG for 2 hrs at a time.
I have tried hitting the green button with CNN on but still get 2 hrs.
How do I get TP 19 ? I do not seem to have it on my set.
Username: Lklives
Post Number: 1640
CNN is TP 19....U have much to learn..
Username: Conti
Post Number: 24
I press the green button when I am on CNN.
Only get 2 hrs. What am I doing wrong ?
How do I get 2 days worth of EPG?
Username: Paint
Post Number: 11
LK, tech question. Do U know what 's different between 3500 & Cool 5000 that gives the 5000 the extended EPG, ie circuitry, processor, programming? just curious
Username: Conti
Post Number: 25
LK, Where can I get some info on EPG?
Username: Paint
Post Number: 13
What kind of info??
Username: Lklives
Post Number: 1679
Must have correct date, time, and time zone to have a working EPG..for Pansat ,its only about 2 hours usually..
Setting the correct date, time, and time zone will fix the EPG (program Guide), which for Pansat is normally only 2 hours or 2 shows displayed ...and hitting the EPG button when on TP 19 (CNN or A&E) will sometimes give U a much longer EPG (48 hrs max) on some channels..on most Pansats..try it .....must keep doing the EPG on TP 19 after changing channel or shutting off...works well on 3500 with bin 143 on the 300 channels
Do the following
Hit Menu
Go to User Setup
Select Time, hit ok
Change timezone (EST, PST etc)
Click on Clock
Change year date and time, PS it is in 24hr mode (military time)...remember its 2006!
U should check this every time U upload a new bin!
Username: Conti
Post Number: 26
I do have 2 hrs worth of EPG. I wanted to get 24hrs EPG.
Looks like the 3500SD gives only 2 hrs at a time, unlike the Pan 5000 that gives 24hrs EPG on some channels.
Thanks for the feedback.
Username: Lklives
Post Number: 1683
and hit the EPG on space channel and get 3 days EPG
