Yamaha DVD S657 all region?
Username: Eurocd
LA, CA US
Does this player come "out of the box" as a code free/region free unit (as advertized on some sites)- dual voltage unit.
Or - is the US Region 1 model just as good for playing PAL DVD's using a remote hack.
Is it a so-called native PAL/NTSC player?
Just interested in watching some PAL and nonR-1 NTSC movies. No copying.
Anybody in the LA area...who sells Yamaha DVD? The chain-stores don't carry Yamaha. Thanks.
Username: Peter07
To make the player multi-region compatible, turn it on, open the tray, press 99990 and then close the tray.
