No rs232 port?
Username: Klitschko
hello i am just setting up a 3500sd and found a great setup guide using a 232 port but the problem with that is my pc has no such port i cant find any other way to program it what can i do should i get a card reader and program it by the sd card? please help thanks
Username: Klitschko
somebody anybody? i read on dsscomm. but this is a much better/easier forum to use
Username: Lklives
Post Number: 1566
then read here...I like dsscommunity forums much better!...they are 1000x easier to read and find things!...U can use the card..I have how to use it all explained for a 10 yr old at dsscommunity..or U can add a serial port to the computer..
Username: Klitschko
thanks lk is the thread in the pansat files? on dsscomm?
Username: Leew
Ketchikan, ALASKA
Post Number: 387
@Klitschko,wassup...buy card reader...it's better.
take look here...
http://www.tigerdirect.com/applications/category/category_slc.asp?Recs=10&Nav=|c:942|&Sort=0
Username: Klitschko
mike lee w^ been a while yeah i bought a 3500 and just got my dish pointed lash night so i should go with card reader? thanks mike
Username: Klitschko
Post Number: 7
thanks mike which thread will walk me thru programming process (writing card with bins etc)
Username: Leew
Ketchikan, ALASKA
Post Number: 388
I did find for you....LK...posted ...nice guide.
copy/paste
LK posted:
3500 - Complete Loading Instructions
How to Load and Save Files to the Pansat 3500S
3500 - THE SD/MMC WAY:
Insert virgin SD/MMC card into receiver.
Press [menu]
Select [SD Memory]
Note: Receiver will automatically create 3 directories on the card:
CH Data Backup
Code Backup
MP3
(For Virgin cards only -Take the card out at this point and load your unzipped bin or channel list file to the card in the appropriate directory. Now put the card back in and re-access via menu as stated above.)
Select bin file in appropriate directory, main directory, [ch data backup] or [code backup]
Press [OK]
Select [data restore]
Press [OK] to load, receiver will automatically load, confirm, then reboot.
TO SAVE DATA
Insert SD/MMC card into receiver.
Press [menu]
Select [SD Memory]
Select an appropriate directory, main directory, [ch data backup] or [code backup] by using [up or down arrows] and [OK]
Press RED button in left bottom corner of remote.
Name your file on the alphanumeric screen file by scrolling via [arrows] to next character and then pressing [OK] for each character or [del] to correct a character. To save selected name, press [OK] on the alphanumeric screen.
Bin File will then write automatically to the correct directory.
Size of files:
CH = 352 kb
Code = 768 kb
Use GREEN button (beside the RED button) to delete selected and unwanted
files.
MP3 PLAYBACK
a) Insert SD CARD into the eceiver SD CARD slot.
b) Select SD memory at Main Menu and press OK button.
c) Select MP 3 file downloaded from PC and press OK button.
d) Select the MP 3 file to play and press OK button.
e) For multiple MP 3 play, use left/right volume buttons to select or cancel the files to play.
All selected files (up to 20) will be played one by one
Username: Leew
Ketchikan, ALASKA
Post Number: 389
and I flashed with:
Pansat 3500SD X-05BL Version 143
Bev and DN autoroll FIX! Dated 03.17.06
The file released it to www.future-fta.info.
Official site for Pansat Receivers!
Supported By Blacklist (BL)
www.future-fta.info
IT'S WORKING... 200%
Username: Klitschko
Post Number: 8
thanks alot mike i appreciate your willingness to teach yeah i went thru emantechnology like u suggested and u know it only took 2 days to get the receiver and a third day for the dish thanks again mike iam going to go down to radioshack now and get a reader, i cant wait! cya soon mike
