Help with 2700a
Username: Dangrafm
Post Number: 9
Hi i tried the Keys provided by LK but iam still getting the bad or scrambled channel. here is what i did
In nagravision 2 in
00 - 4D 2A DC 33 D4 CD E3 75
01 - 24 2B F0 4F 03 68 06 92
and also i tired 00 - 9E 5B 7A 77 C0 FE 91 CA
but it didnt work. i only have one line on Nagra vision 2 for 00 and 01 can some1 please help me.
Do i have to change my nagra vision 1 keyS>
Thanks
Username: Gmush
OK THE NEW KEYS ARE FOR NAG2 ARE:
00-4D 2A CD D4 33 DC E4 84
01-F0 5F 99 8D 9G 88 4E 10
ENJOY FREE TV.
Username: The_wank_artist
Post Number: 12
fake LK posted above.
Try these.
FB D9 F2 D9 D6 C9 EF 7A
57 AD 32 24 67 42 6C E6
These are from keymaster as of Friday.
Username: Vndpatel
Post Number: 11
download bin 143 and put in key
two times once as 00 and once as 01
i did that and it worked for me and then i did blind scan.
Username: Lklives
Post Number: 1459
Those are not the active DN keys!
Username: Bowlingdad
Post Number: 9
ARE CURRENTLY NOT ACTIVE.
Username: 1000ton
is there a new set of keys for Nagra 2 that can be provide to my attention?
Your assistance is greatly apprecited...
Thanks
Username: Lklives
Post Number: 1466
Bowlind Dad...U are a scammer...go away!
All U people who can't find the correct keys are just plain LAZY...I posted them here 3 days ago in the "keys" thread...the most obvious place!!
DISH NETWORK N2 keys...17 Mar 06
Idea Key 0:
Idea Key 1:
C5 6C 66 89 3A 32 D0 C9
24 2B F0 4F 03 68 06 92...... Key 1 new Active key
Coo*lsat: KEY Line 10 and 11 are for Idea Key 0 and Line 20 and 21 are for Idea Key 1
Pansat: key 00 for Idea Key 0 and Key 01 for Idea key 1
Viewsat: line 08 and 09 for Idea Key 0 and lines 88 and 89 for Idea key 1
For Receivers with only two Key Lines, Enter Active Idea Key into 00 and 01
Username: Dangrafm
Post Number: 10
LK,
That's what i tried, as i described in my first post and its not working, Can you please tell me what iam doing wrong.
Post Number: 13
LK,
the keymaster v2.0 that I have lists the keys as I posted above. You saying that the ID key 1 is different than the one I listed.
The keymaster I use is from DSS Central. How come the difference?
I use to use keymaster when I got my dish back in November but haven't used it since December when I started using bin auto rolls.
I still check the keymaster every now and then just to see how often the keys are changing.
Do these key gen's applications get out of date? As the Keymaster launches to web site and date stamped when changed I figured that they were current
When I open Keymaster today, it's still saying as of March 17th, 12:12 pm.
Username: Al_bundy
Key 0: 9E 5B 7A 77 C0 FE 91 CA
4D 2A DC 33 D4 CD E3 75 Active
Key 1: C5 6C 66 89 3A 32 D0 C9
if you are using the latest bin just hit set default keys.
if you are using a non auto roll bin the hit set default keys then enter them manually to the ones i posted above.
i have a non auto roll working with the keys i posted.
Username: 1000ton
Thank you all, it seems that the keys provided are working.............
Username: Dangrafm
Post Number: 11
Thanks al bundy for the help, but still i have a question. as i mentioned i only have 1 line for 00 and 01 for nagran vision 2 which key do i put it. i would really appriciate yourhelp.
Username: Tompaok
any one tell me how i put the letters becauseany time when i try only numbers comethe time
Post Number: 14
khan,
Using a Pansat?
If so, you should see 3 separate sections in the Nagravision section.
Provider ID: (DN or BEV id)
Key Number: (00 or 01)
Key Data: (two lines for 16 character keys)
You'll notice that on Key Number you can use the remote to scroll right, and that should give you the 01 line.
Username: 1000ton
in the menu that you see when you try to put the new key, you will see at the bottom that is a description of the diferent keys in your remoto that represent different letters, for instace , pansat remoto control letters are :
pause=A Audio=B epg=C last=D fav=E sat=F
Username: Tompaok
how can i put numbers and letters in the key any time i try only numbers show how i do the letters sory i am new in this
Username: 1000ton
are you using a Pansat remote control????
if yes, numbers are numbers and the leters need to be entered by pressing the different keys in the menu.......
Username: 1000ton
can samebody tell me why I'm lossing the picture when I have full signal????
is there any explanation to that or is normal>>>>>as Tom mention......I'm new on this
Username: Dangrafm
Post Number: 12
Yes, iam using a Pansat 2700a, but thats my biggest problem, i only have 1 line each for Key 00 and Key 01 that only takes 9 characters per line.i dont have two sets of line in my nagravision 2
Username: Lklives
Post Number: 1468
For Receivers with only two Key Lines, Enter Active Idea Key into 00 and 01...
00...C5 6C 66 89 3A 32 D0 C9
01...24 2B F0 4F 03 68 06 92
khan...U are not seeing correctly...the wanker's post above is 100% correct!
Username: Lklives
Post Number: 1471
khan...Your screen should look just EXACTLY like the pictures in the 1st 2 posts of this linked thread!...with even the same keys as in the pictures!
https://www.ecoustics.com/electronics/forum/home-video/208936.html
Username: Tompaok
any one has new bin file
Username: Al_bundy
khan what flash are you using??
sounds like you may have an old flash.
the 2700a is now at 146.143 seems to be working too. 143 is auto roll.
if you dont want the auto roll bin i believe its 122. future fta has the latest bin
Username: Rbvip
Peterborough, Ont Can
I am having trouble with my pansat 2700a. I have realigned the dish, but still no pic. I reset the keys to rhe ones listed above C5 6C etc, for 00, and then 24, FB etc for 01. Are these the right keys could someone help me?
Username: Nba2006
LK what u think of the recievers with a card ??? Any good ? i want to get a satellite reciever but im confused between The Pansa***t 3500 and the card ones ?? i heard that FTA systems sooon to be gone. PLease let me know whats better. thanx
Username: Grimreeper
Post Number: 26
If the fta is soon be be gone the carded will be gone to.Its all crapshoot the pansat3500 is a good piece aswell as the viewsat extreme and the coolsat5000 if you can get a sweet deal on a carded setup gofor it aslong as theyll help when it goes down or keychange and so on
Username: Dangrafm
Post Number: 13
Hey Guys i tired the Keys that LK provided in the post. and i also tried set defalut keys, but still nothing please help. do i need to change my bin??
Username: Lklives
Post Number: 1512
dunno...U're the one trying to set up the receiver!...we provide some correct info...U must follow it..maybe u should go back and read a setup manual..there are 4 lines...u do not know what U are talking about...sorry but, its the truth..
Username: Nba2006
any one know if you can hook up two recievers through loopback ???? there is a loopback thing in the back of my reciever and someone told me that u can hook both recievers up through loopback cuz i dont have Dual LNB on my dish... If someone know please help thank you
Username: Lklives
Post Number: 1528
never heard of it....and don't believe it..
Username: Wakenbake
Post Number: 8
loop out : can be used to hook up1 receiver another w/ restrictions, 1st receiver is the master, 2nd is the slave(can only watch channels on that transponder)turn off first receiver in line the next becomes the master.
Username: Lklives
Post Number: 1556
so its just like running a splitter to a 2nd TV...2nd receiver receives only the channels that the 1st receiver is on..
