No info on the epg 2700a
Username: Yourfriend
Post Number: 12
Hi Lk, Mike W. Lee or anyone:
I have a pansat 2700a. I am using bin 145 and watch Bev sat. I change the time to my location, but still get no info on the EPG. Please help anyone. thanks.
Nickey
Username: Geeker
Post Number: 80
fix your TIDs and NIDs and you will have EPG. I have done it just yesterday, and it worked perfectly so far.
Post Number: 13
Hi Geek Geek
I am sorry, but what do you mean to fix TIDS and NIDS? Please help,thanks
Post Number: 15
Hi Geek Geek
I am sorry, but what do you mean to fix TIDS and NIDS? Please help,anyone! thanks
Username: Leew
Ketchikan, ALASKA
Post Number: 349
Network_id (nid) showing a
network to broadcast the program; Transport Stream_id (tid) showing a
physical channel for the program; Service_id (sid) showing a logical
channel for the program; and Event_id (eid) that identifies the
program within the channel for the program. This combination of the
identifiers is the aforementioned program ID information, and the term
"program ID information" is hereafter used to represent this
combination.
Username: Leew
Ketchikan, ALASKA
Post Number: 350
@nickey ,check it out ,date and time...Somehow, once a week
my receiver change it years, 2006 to 2056 ,then autoroll stop working too , not just epg...
Post Number: 17
thanks Mike W. Lee! you have been help me many time. How have you been? Haven't see u here for a while. again thanks!
Nickey
Username: Leew
Ketchikan, ALASKA
Post Number: 355
Thanks Nickey, I am ok,how are you? I hope you ok and you got wide open TV. By mistake I got CD,from e-bay,for dreambox...(all info...eg..how to....reprogram,how to set up dish ,which lnb to install..),even there is program to open BIN file with full instruction and foto how to correct autoroll and where to write new key and ....,it cost me 19.99$,but it's realy very very usefull info.So I wanna get the same one for Pansat.In 3 weeks I think I'll get it.
Thats my story.
Post Number: 18
Great thanks! That sound good! where in ebay, I can find this cd, what it is call? Maybe I will get one too. Welcome back!
Username: Leew
Ketchikan, ALASKA
Post Number: 357
I got from this friend :http://search.ebay.com/_W0QQsassZsat_dishQQhtZ-1
Post Number: 21
when u get it, let me know how is the CD work please.
what happen to Lk? IF he leave here, we will miss a lot. He is a great Helper.
Username: Lklives
Post Number: 1416
I am at dsstester and dscommunity already helping with the new keys today and the autoroll fix..U will all be without TV tonight...I do NOT support thissite if it does NOT support me!
Username: Geeker
Post Number: 81
@nickey, You have to be able to use channel master in order to change the the NIDs and TIDs. Mike has already explained to you what's the NID and TID. Find the channel master software, install it, then download your scanned list from your STB. Open the list you just scanned, and bulk change your NIDs. Your TIDs should be good, at least mine were correct on my list. Finally save the changes to your list, then upload the saved list back to your STB. Pluck your receiver turn on, and you should have a good epg if your timezone and date are correct.
Username: Leew
Ketchikan, ALASKA
Post Number: 363
Nickey,take chanell master here:http://www.sharpc.com/CM/History.aspx
just pick new one.I used,it's good.
Username: Kingyousuf
Post Number: 27
Hi, i am nit getting any channels. The channel comes on for 1 minute and goes out for 10 minutes.
I have the BIN 144.
Can someone help...... I am trying go to dsscommunity but it is not working properly.
HELP ME
