Missing channels...help me plzzzz
Username: Malhib24
Im wondering what the problem could be Ive tried to power down, tried to re-scan tried blind scans but still missing about 20 channels overall especially off the international dish, and a few from 110 and 119....could this be because i need to try and download a new bin? I tried the other transponders as well but still no luck can someone plz help me out id really appreciate it.
answerman
change the satellite name to something else, then rescan!
Username: Lklives
Post Number: 1210
U rename the satellite when U are missing an entire satellite , like Echo110 to Dish 110 when using an autoroll bin...not when just missing a few channels..
all U can do is NOT use a channel list, delete all your present channels,..unhook the disque switch, and run cables directly to receiver one at a time from LNB and do seperate satellite scans..then hook the disque switch back up..other than that, its doing TP scans..or U have some weak signals that your dish just can't get, due to weather,old cables,bad connections etc..
