Pansat 2700 Dish 500 or Dish Pro 500 and LNBF
Username: Cadavis
Atoka, OK USA
Post Number: 11
If I have a Pansat 2700a Receiver and Ku LNBF Spitfire Model:ASC321 LNBF's will they mount on Dish 500 or Dish Pro 500 support and work? I was thinking about getting another dish and I already have the LNB's and I know the support arms are a different size. They sell the Dish 500 with the LNB's already, but I don't know if the LNB's are compatiable with my reciever or not.
Username: Cadavis
Atoka, OK USA
Post Number: 12
http://www.thesatshack.com/elliptical-satellite-dish.html
They state that the 149.00 dish and LNB setup there at the top of the page will work with their receivers....they don't sell Pansat, but I am assuming it will work on one.
Username: Lklives
Post Number: 1127
U need to provide info on that LNB..is it a regular KU circular LNB?...if so it should fit on any dish with the appropriate mounting bracket.....Dish 500 LNB's are compatable with any FTA receiver as long as they are NOT legacy Twin or quads..
Username: Lklives
Post Number: 1128
The ONLY spitfire I know was my old Austin Healy..
Username: Cadavis
Atoka, OK USA
Post Number: 13
http://www.dvbhardware.com/product_info.php?products_id=21
that is the LNB that I have..a cheapy that came with the receiver and dish in a combo when I started this whole journey.
Technical Specifications
Input freq. range: 11.70 to 12.20GHz:
L.o. frequency:range: 10.75GHz (1MHz @ 25 degree Celsius)
L.o. stability range: 2MHz (-40 to +70 degree Celsius)
Output freq. range: 950 to 1450MHz
Noise figure:range: 0.7dB typ.
Conversion gain 55dB typ.
Input VSWR: 2.5:1
Output VSWR 2.0:1 (max.)
Output connector: F-female connector
Output impedance: 75 ohms typ.
Cross polar isolation 20dB (min.)
Image rejection: 45dB
Phase noise: -50dBc @ 1KHz
-75dBc @ 10KHz
-95dBc @ 100KHz
Supply voltage: Ca: 11.5 to 14.0V (vertical pol) 13 VDC typ.Cb: 16.0 to 19.0V (horizontal pol)
Operating temperature: -40 to +70 degree Celsius
Storage temperature: -40 to +80 degree Celsius
Relative humidity: 0% to 95%
Size: 136mm x 53mm x 53.6mm
