New member Username: Mc_sunnyPost Number: 1 Registered: Feb-06 | For Fortec Lifetime Ultra receiver,can someone tell me how u do autoroll for it step by step plz and thanks. | |
Silver Member Username: LklivesPost Number: 760 Registered: Jan-06 | Go read at a DSS site that has manuals and files.. BTW...autoroll is uploaded same as any bin, no different, except "set the default key".. |
New member Username: Mc_sunnyPost Number: 2 Registered: Feb-06 | Thanks Lk ...how u install a bin i don't even know that, just new to all this i been doing reading here can't find out plz help me out | |
Bronze Member Username: LeewKetchikan, ALASKA Post Number: 58 Registered: Jan-06 |
New member Username: Mc_sunnyPost Number: 3 Registered: Feb-06 | Thanks Mike | |
Bronze Member Username: LeewKetchikan, ALASKA Post Number: 59 Registered: Jan-06 | Any time ! | |
Bronze Member Username: PrfrmnjPost Number: 69 Registered: Oct-05 | For all you Fortec users. If you had read the new v. old fortec thread, you would have seen the 2 resistor mod which is pretty much the way to go to solve you problems. Once you've done the mod, load bin 271t and this will convert you're fortec into pansat along with a fully working autoroll. This is for the 614 tuner. Chipset really means nothing with this mod so don't bother with it. I have done this mod to at least 15 receivers and they are all up and running. There is a single resistor mod for the 624 tuner, but I have not worked with it yet, so I can't tell you if it works. | |
Daniel Lourine Unregistered guest | Hey LK, i have the bin 144 and my satellite is down (for about 2 hours) and it doesn't seem like the autoroll is working is their something extra i have to do. Can he tell me wat i should do to get my satellite up using autoroll. |
