Ca't get channels back!!!!!!!!
new bee
i did a factory reset and i cant get my channles back the ones i get they have that $ sign in front of them i don't want to download nothing so if there's another way fix please tell me.
Username: Stupidbush
Arkansas, Arkansas Bangladesh
Post Number: 41
you're a dummy cat..
take thisUpload
Username: Lklives
Post Number: 754
U need to do a blind scan or sat scans..
Username: Siberian_phil
Post Number: 14
LK or BABA KHAN or anybody who has digiwave 7000
I get it.For digiwave i have to put key 00 and 01 in one first line(key 00 in my resiever)My problem now I killed line two (it's named KeyM1 in my resiever)How I can get it back?MAyby somebody can printed for me please.Or Ihave to flash it now and put new BIN? Halp please.Thanks.
Username: Lklives
Post Number: 757
phil...quit asking and just do something!...anything!...reapply the factory settings or factory bin..that should reset it..then upolad a newer bin
No I don't have it...look for it at DSS sites where they have files...as U know, there are NO files here..
Post Number: 15
LK... Had an idea to do by ease way.OK I ll do all from the beginning.Thanks for your patient.Becouse Iam ready to crash Digiwave and bite myself a-s.I am not bronze member - wooden.
But,full of enthusiasm.
new bee
lk.. i did that i tried both blind scan and sat scan but all the channels have that$ sing in front of them is there a way to fix this without having to download anything
Username: Raging_fisher
Do you have the latest .bin file installed??
new bee
im telling u i can't download stuff in to it
All of my channels have a $ sign in front of them, and they all work just fine.
Your factory bin isn't going to do very much for you.
Download the newest bin, which should be autorolling, and you should be good until BEV/DN start f^cking around again.
You should have an RS232 Port on the back of the Receiver, go down to the local computer shop and buy a null modem cable for $10. Download the uploader and bin file, and you will be back in business.
