I cant download stuff in to my pansat 2500a
Username: Lokoz
Post Number: 13
i cant download stuff in to my pansat 2500a i dont really know ?'s the problem can some one help me im just a beginner i dont really know anything about this tnx.
Username: Maple_leaf
Post Number: 1309
https://www.ecoustics.com/electronics/forum/home-video/197659.html
Go there and read last post.
Username: Lokoz
Post Number: 14
i need help i dont need that
Post Number: 1310
You need to go to a site that sells and deals with them . Won't where you bought it help you?
Username: Kneegrow_2
maple leaf shut the hell up
alrite lokoz jb,tell me what bin you are flashing and what program you are using to flash it
give me your email address and i will tell you how and send u all you need to get it up and running
Post Number: 1311
knee grow
You help him if you want but don't tell me what to do little man. First and only warning!!!!!!!!!!!!!!!!
This site is going fine without your kind here and it's not going to start again. SO PULL IN YOUR HORNS NOW.
better listen up ///////
Username: Lokoz
Post Number: 20
hey knee grow my e-mail adress is ricardo_g_steel@yahoo.com
Post Number: 8
i sent instructions and files out to u lokoz jb,tell me if it works
maple leaf im jus sayin dont be so mean to the noobs
Post Number: 1312
knee grow
Ok no problem then. I hope you can help him cause he really needs it.
Username: Goodie
Oak hill, Ohio U.s.
I need help programing my Pansat 2500
Username: Radd9088
I bought a Pansat 2500A 3 days ago and it was working fine until I went to download a fix. I used the Pansat STB updater to download the fix. I followed the instructions carefully and now it do not work. The screen is blank when I reconnect the receiver, and I cant turn the receiver on/off with the remote. The receiver turns on from the back of the receiver and signal ON on the display. Can you tell me what is wrong with the receiver, or what I am not doing right.
Username: Lklives
Post Number: 697
Read the "Pansat Set Up Guide" thread here..
https://www.ecoustics.com/electronics/forum/home-video/196906.html
