Missing a few channels 140~147
ViniDomine
My friend is missing ESPN and some other channels... 140... 141 142...etc..
He has a Dish500 with two duo DP LNBs going through a sw21.
Receiver C00Lsat 5000. Both birds 110 and 119 have good signal and diseqc is set properly.
Blind scan runs smoothly with the appropriate channels from each location... but when we check for ie.: channel 140... its missing.
Any ideas? Thanks.
ViniDomine
Username: Lklives
Post Number: 788
yes idea..your friend is not too smart..U do not use sw21 switches with FTA...and with DP LNB's...
if missing channels, scans are made just for that!
nonamefacee
the channels are down due to TP changes.
coolSt 5000 can work on sw21 and 500.
the issue is the TPs re scan and it will be back. in the future it will do that for you..
www.freetoairreceivers.com great prices great product
Username: Lklives
Post Number: 791
Yes the next generation bins will have auto TP scans..now U must do your own TP scans manually..DN has been moving channels around to differ t TP's (transponders)...especially various PPV sports events and packages right before game start..its all about anti-piracy..
