New member Username: F_t_aPost Number: 1 Registered: Feb-06 | BL is on it...this was expected...no keys rolling...packets been sent to confuse FTA boxes only...new bin in about 15 minutes for pansats only....sorry...not sure for other stb's...bin only at future fta.... |
New member Username: F_t_aPost Number: 2 Registered: Feb-06 | Testing new bin now...will be out shortly...please be patient.... |
Anonymous | test this! |
Nuggets Unregistered guest | Just put in a non-auto roll bin like 264 for my Pansat 2500, enter keys manually and all is good to go. |
New member Username: Peabody67gtoPost Number: 1 Registered: Feb-06 | Hello, New to this forum. Anyway, thanks for your work. I am very patient. Will this new bin fix bev & dish? THANKS |
New member Username: SleeperPost Number: 1 Registered: Feb-06 | Hi, I'm also new to the forum, where do you download the expected fix? any information would be much appreciated, Thanks. |
New member Username: Peabody67gtoPost Number: 2 Registered: Feb-06 | Maybe he will just list it in this post. I hope |
Anonymous | Thanks Chicken..... We appreciate it. |
New member Username: SleeperPost Number: 3 Registered: Feb-06 | yes thankyou chicken its greatly appriciated |
chickN 2nite Unregistered guest | yes thank you, i like chicken wings |
Anonymous | My Twinhan still works, but the 2500 doesn't. |
dario_dee Unregistered guest | where can I find a non autoroll bin like bin 264? Thanks |
New member Username: F_t_a_is_backPost Number: 1 Registered: Feb-06 | Someone does not want me to post here could not log in...I am just trying to help you guys...bin is being tested now...I knew the bashing would start as soon as I posted here...I know who it is but I will help you guys anyway...Future is down so update to bin can be done...patience please... Chicken |
New member Username: F_t_a_is_backPost Number: 2 Registered: Feb-06 | I don't know how to upload file here...if someone let's me know I will upload to you guy's...future-fta will be very hard to get into Chicken |
New member Username: HtodacPost Number: 1 Registered: Feb-06 | how about on has h h u DOT COM |
New member Username: SleeperPost Number: 4 Registered: Feb-06 | cna you please email it to me |
New member Username: HtodacPost Number: 2 Registered: Feb-06 | Will this work for 2700a? Keep up the good work!!! |
New member Username: F_t_a_is_backPost Number: 3 Registered: Feb-06 | Support only for all Pansat...viewsat to follow... |
New member Username: Khopadi1Post Number: 6 Registered: Mar-05 | hi, what bin should i use for pansat 2700a non auto roll version thanks |
New member Username: F_t_a_is_backPost Number: 4 Registered: Feb-06 | 129 |
New member Username: F_t_a_is_backPost Number: 5 Registered: Feb-06 | Sorry guys I don't know how to upload to this site...the bin for pansat's and viewsat's are at Future-FTA...get files there... enjoy |
New member Username: SleeperPost Number: 5 Registered: Feb-06 | hey fta please can you email it to me |
New member Username: F_t_a_is_backPost Number: 6 Registered: Feb-06 | c manek, what stb do you have? |
New member Username: SleeperPost Number: 6 Registered: Feb-06 | just click upload image or attachment button nest to post message button and point the file |
New member Username: SleeperPost Number: 7 Registered: Feb-06 | stp? ihave pansat 3000 |
New member Username: F_t_a_is_backPost Number: 7 Registered: Feb-06 | I did it, but I don't know where it went...please share with everyone...let me know if you got it and post so others can use file... |
New member Username: SleeperPost Number: 8 Registered: Feb-06 | here is my email cmanek@sympatico.ca |
Anonymous | if I find you some space to upload the file to, would that be ok |
New member Username: F_t_a_is_backPost Number: 8 Registered: Feb-06 | I perfer to put it up on site so everyone can download...do you know how?...I tried the upload button but it looks like it did'nt work... |
New member Username: SleeperPost Number: 9 Registered: Feb-06 | email it and i will upload adn give you all the credit |
New member Username: F_t_a_is_backPost Number: 9 Registered: Feb-06 | very unsecure...I'm sure you know what I mean... |
1IJack Unregistered guest | FTA is ___ , if you have the new bins, put it somewhere... put it on the well known forums where it is secure instead of holding out. far as i am aware, BL is still working on it and that is the case for you, you should say so as folks dont continue to wait tonight for your post. OneEyeJack |
New member Username: F_t_a_is_backPost Number: 10 Registered: Feb-06 | Jack tell me where to upload |
Bronze Member Username: F_t_a_is_backPost Number: 11 Registered: Feb-06 | I am not holding out...I just don't know where to upload... |
New member Username: TikibobsPost Number: 1 Registered: Feb-06 | dssrookie.com/forums/pansat/this-will-fix-your-2700-problems-65216.html |
New member Username: TikibobsPost Number: 2 Registered: Feb-06 | don't know if you guys are experiancing the same thing, but my TV has been working for 20 minutes now and I haven't done anything to it...it was rolling most of the night.... |
Bronze Member Username: F_t_a_is_backPost Number: 12 Registered: Feb-06 | tiki...how do I upload bin to this site???? |
Bronze Member Username: F_t_a_is_backPost Number: 13 Registered: Feb-06 | I have tried to upload bin to you guys with no success...go to Future-FTA and download... x-87BL_060203_143_au_api... |
Bronze Member Username: SleeperPost Number: 11 Registered: Feb-06 | tried to upload but site is in maintance mode so here is the link after update make sure you set default key it seem to be working for last 20 mins hope it helps |
ViniDomine Unregistered guest | just FYI... Pansat 2700A bin 143 works flawlessly. another bin with auto TP to follow soon. regards Vini |
tho Unregistered guest | 143 seems to work, but the receiver does not respond to the remote as well as 140 or 142. I use the extender and can feel the difference with some bins. I will try a non-auto roll tomorrow. It's 4 AM 8^( |
Bronze Member Username: StupidbushArkansas, Arkansas Bangladesh Post Number: 37 Registered: Jan-06 | olso 134 is working pretty well this mourning![]() |
Anonymous | Thanks F T A IS BACK, 143 did the trick, I got it over at the rookie site. I just loaded it and it works 4.0 now. (had me scared at first got that wait for picture msg for about 30 seconds) |
What-bout3500S? Unregistered guest | Anyone having trouble with the new 239 bin for pansat3500s? Mine keep on doin the 'wait for pic' like it was for 138 bin. |
cojones Unregistered guest | Does the 143 work with pansat 3500s? |
cojones Unregistered guest | hey what-bout3500s? , i downloaded that bin but im not at home so have not tested it yet. Have you heard from anyone that has been succesfull with it yet? |
New member Username: TonylorancaPost Number: 3 Registered: Feb-06 | pansata 2500 bin 271 autoroll working good |
New member Username: FlashmanPost Number: 4 Registered: Sep-05 | 2700 bin 129 [manual with no autoroll] Nag 2 keys - 00 01 00 Only [do nothing with 01] FB D9 F2 D9 D6 C9 EF 7A 57 AD 32 24 67 42 6C E6 Can get bin at abadss.com [need to register but it is free]. Also has bin fix for others including 2500 [bin 256] and 3500 [bin 126] |
Sharp Unregistered guest | I can;t get my Pansay 2700a to work . It loses the picture every 3-5 min,than reloads and serched for the picture agian.What is the prob and how do I fix Thanks |
Anonymous | Please clarify, what BIN will work on a Pansat 2500 and where can I get it. I have not been able to get into Al7bar or fta-future, probably because sites overloaded |
Anonymous | my e-mail is tony_loranca@hotmail.com i have the 271 working |
Silver Member Username: Slo_hand2Post Number: 335 Registered: May-05 | bin 143 working perfectly. |
Anonymous | I don't care if it works or not, I just want two more Favorites slots. |
New member Username: DishcrayzeePost Number: 4 Registered: Jan-06 | Can someone please email me a working bin for Pansat 2700. Much appreciated. dishcrayzee@hotmail.com |
Anonymous | can someone help me for pansat 2300A...i think i need new keys...plz n thxs |
New member Username: Phil82Post Number: 2 Registered: Feb-06 | I was just wondering if anyone has figured out how to fix the pansat 3500 problem with the autoroll. If it is a case of getting a non autoroll .bin, can someone tell me where i can find that and the new keys i would need. Thanks |
Anonymous | Chicken where are da new keys |
Silver Member Username: Slo_hand2Post Number: 336 Registered: May-05 | I know the site is slammed right now but if you are patient and try to get future-FTa.info you will find the latest bins for all pansats. |
New member Username: ProudjawPost Number: 1 Registered: Feb-06 | I'm new to FTA. I have a viewsat 2000. It went down last night and I can't get a hold of the guy who sold it to me. Where do you go to download the new patches and stuff. I seriously have no idea and any help would be greatly appreciated on super bowl weekend!!!!! THANKS! |
bombats Unregistered guest | hey slo what is future-fta sorry but i have tried.c*m and .info and nothing works....and will this work for pansat 2300 |
New member Username: Special_kPost Number: 1 Registered: Feb-06 | Hi! Please HELP! I got a Pansat 2700A. I'm getting most of the channels using: FB D9 F2 D9 D6 C9 EF 7A 57 AD 32 24 67 42 6C E6 As of this morning I do not get a single ABC channel! Tomorrow is Super Bowl And I MUST be able to see it. |
billy big weenie Unregistered guest | my pansat 2500 is not working after numerous attempts, i just need to what bin is working because some bins do not allow for the nagra 2 input. So i need the right bin, already got the keys and the channel list ans have no problem doing a manual input of keys. |
billy big weenie Unregistered guest | does anyone even read here anymore ???????????????????? |
Bronze Member Username: TruckerPost Number: 21 Registered: Oct-05 | "billy big weenie" 271 bin is the latest. load it, blind scan sats, and set default key. |
Anonymous | abc and cnn and a couple other channels are gone i have done a satalite scan but still cant find them any ideas or any suggestions anyone. thank you ps i am running a pansat 2500 not a clone |
