How To input keys..
Username: Thill1951akalk
Post Number: 1172
For All Pansats
Press menu button on your remote:
#1 Go to parental control...
#2 Go down to "second pin" option & enter 0000
#3 Then go to nagravision and select it by pressing ok button on your remote...
#4 In Nagravision window you should be in the box that is Entitled "Provider ID"...scroll to the right (press right arrow button on remote) until it switches to Dishnetwork (00 01)
#5 Now In Nagravision window go down (press down arrow on remote) to the box that contains "00" entitled "Key Number"
#6 While in the box (highlighted "Key Number") that contains "00", scroll to the right until you see nagravision 2 at the top left of your screen
#7 While in Nagravision2 you should still be in "Key Number" box and the number in that same box should be "00"...this is for Key 00
#8 Scroll down (press down arrow on remote) to key data and enter the new supplied key for 00 (within this site is the key change for Nagravision2)..take note on how to enter letters in the lower portion of the screen (ex. letter E=FAV button on remote)
#9 Once key is edited select OK button on your remote (OK-STORE confirmation blinks twice in lower right of screen)
#10 go back to the "00" box and move one click to the right which should take you to "01"..this is to edit the "01" key
#11 Follow Steps 8 & 9 above (this time enter key data for key 01 instead of 00)
#12 Click exit and click ok or yes to save changes then exit all the way out and you should be watching tv
Note...For /Bell keys at step #4, "Provider ID" is 09 - 01
Post Number: 1173
How To Manually Enter N2 Keys For C*oolsats:
To enter N2 keys manually you must have the C*oolsat superbin or latest bin with edit keys feature flashed to your receiver.
Enter 8282 with remote as if choosing channel to open CAS Menu
Use volume up and down button on remote to scroll to Nagravision ( Dish Network Provider Ident 0001 ) Use channel up and down button on remote to scroll to different Key Slot IDs and Key Slots.
Enter the keys . Use the Info button for letters A-F . Press it once for A , twice for B , Etc and channel number key pad for number entries Or you can press OK and it will open a Keyboard selection type menu to enter keys.
You will see the following Key Slots:
10 Key
11 key
20 Key
21 Key
Post Edit: After testing I can confirm the bin editor will write to the bin with revised super bin version 1.0 and 1.1. The key slots used for N2 keys is the key slots 10 and 11. Tests of all 4 slots in various combinations reveal 20 and 21 slots have no bearing on signal decryption and correct keys must be inserted in the 10 slot for 00 key and 11 slot for 01 keys. I will note the bin will load the 00 and 01 keys duplicated within the 10 and 11 slots also appearing in the 20 and 21 slots.
When key change is complete, Press Exit and confirm key change save.
basically ..Idea key 0 on 10-11 lines, and Idea key 1 input into 20-21 lines.
Post Number: 1174
C*oolsat - How to change Keys
Changing Your c*oolsat 4000 keys (Step by Step) Illustration
Before you can accomplish the folowing intructions you will need Keymaster 2.0.
I can only illustrate intructions without the keys. You will have to use the Keymaster 2.0 to obtain the current keys.
MANUAL KEY ENTRY INSTRUCTIONS FOR C*OOLSAT PRO 4000:
Instructions for Dishnet:
Find and select satellite tab: NAGRAVISION (00 01)
Once you locate the above mentioned tabK
You must change the values of that screen to this:
10: XX XX XX XX XX XX XX XX
11: XX XX XX XX XX XX XX XX
00: 00 00 00 00 00 00 00 00
01: 00 00 00 00 00 00 00 00 and save it.
If the above key entry instructions does not work for you on dishenet (NAGRAVISION (00 01)?
Change it to the instructions indicated above to the one illustrated below:
(Remember: This XX characters whould be replaced by the actual keys from keymaster) The zeros are actual key entry values needed, to make it work.
20: XX XX XX XX XX XX XX XX
21: XX XX XX XX XX XX XX XX
(Notice: That the #10 and #11 above are now #20 and #21 on this sample)
On some receivers, this is the only way it works!
For BeLL
Select satellite tab: NAGRAVISION (08 01)
BELLV= Provider 0801
Nimiq N2 Keys
Must change whatever contents on this screen to CURRENT keys:
Remember: Because I cannot actually provide you with the keys, I can only illustrate what to do.
You must adquire the real values using Keymaster 2.0
Remember... No keys are allowed to be diplayed by the rules here, so I can only illustrate intructions without the keys. You will have to use the Keymaster 2.0 to obtain the current keys.
Key : xx xx xx xx xx xx xx xx
A walk trough illustration of what to do: (To enter keys manuallyfº
1) Turn On Receiver
2) On the remote control press 8282
When the key window appears:
On the top of your screen, you will see many tabs with options like Saca, Nagravision, etc. Scroll left or right until you find the one that has the following information on it:
NAGRAVISION
(00 01)
When you find the tab that matches the items mentioned aboveK
On the bottom of that NAGRAVISION (00 01) tab or choice, you will see a window with four lines, which contain letters and numbers'K Scroll down using your remote to the first line with the letters and numbers and make the following changes indicated below:
Note:
The following illustration below is only used for as a guide to illustrate to you what to do. It does not necessarily mean that you will find the same letters or numbers displayed below: (they more likely to be much different) But. I use it to guide you in the process to show you what to do:
It would look something like this below:
(Remember: This XX characters whould actually be different in your receiver.
You can find the actual keys from keymaster) The zeros are actual key entry values needed, to make it work.
11 XX XX XX XX XX XX XX XX
10 XX XX XX XX XX XX XX XX
00 XX XX XX XX XX XX XX XX
01 XX XX XX XX XX XX XX XX
Change all of that to this:
Post Number: 1175
For C*oolsat
go to ch 8282
and look for nagravison 2
dishnetwork
keys 10---AF-0C-BD-48-D8-51-6D-DC ...Idea key 0
keys 11--- FE-44-D6-0C-A3-6E-59-42 ...Idea key 0
keys 20---3D-73-19-22-27-5D-C2-C9 ...idea key 1
keys 21---97-96-5A-0C-A5-79-27-F9 ...Idea key 1
Post Number: 1176
Viewsat lines 08 and 09 hold Idea key 1 and 88 and 89 hold Idea key 0...all 4 lines must have the correct keys to receive all the channels..
A N2 key now is 32 bytes divided into two string lines of 16 bytes each. The idea key 0 goes into lines 08 and 09 in the code option and idea key 1 goes into lines 88 and 89 in the code option. As with N1 encryption, usually one idea key is active and the other is not. If you know the active key but unsure if it is the 0 key or 1 key, you can enter the key twice, repeating the 08 and 09 entries in 88 and 89 lines. This is not recommended as we see dish will run two active keys at one time.
Post Number: 1177
You can do it two ways:
1. load the latest opkey file... see posts below for the currently active on dated Dec 3 7 pm
2. use your REMOTE control... here's a "ficticious" example when you have the KEYs to use your REMOTE:
PRETEND Public Key Change by teach (12-04-05)
The Public Keys are reported to have changed to:
Key 00: F2 98 74 44 1C 65 77 D8
Key 01: 17 E3 E1 1D 89 4E 53 45
Here's how to change them in your ViewSat:
MENU--INSTALLATION--CODE--NAGRA
LEFT arrow until "Dish" displays in the top line
DOWN arrow x 2
RIGHT arrow x 1 puts you on the 2nd line of numbers with "08" in the first column;
you start punching in the below at the 2nd column ("C3" as of 11-04-05)
"Text" key + "2" = "F2", RIGHT arrow
"9" + "8" = "98", RIGHT arrow
"7" + "4" = "74", RIGHT arrow
"4" + "4" = "44", RIGHT arrow
"1" + "F3" key = "1C", RIGHT arrow
"6" + "5" = "65", RIGHT arrow
"7" + "7" = "77", RIGHT arrow
"F4" key + "8" = "D8", RIGHT arrow ...
finishing the top line
You should have the highlighted box in the first column of the 2nd row on top of "08"
DOWN arrow, RIGHT arrow to the 2nd box in the 3rd row
"1" + "7" = "17, RIGHT arrow
"LAST CHANNEL" key (below "9" key) + "3" = "E3", RIGHT arrow
"LAST CHANNEL" key (below "9" key) + "1" = "E1", RIGHT arrow
"1" + "F4" key = "1D", RIGHT arrow
"8" + "9" = "89", RIGHT arrow
"4" + "LAST CHANNEL" key = "4E", RIGHT arrow
"5" + "3" = "53", RIGHT arrow
"4" + "5" = "45", RIGHT arrow
EXIT, "YES" to save
EXIT to TV screen and watch tv
This puts the PRETEND KEYS into the 08 & 09 KEY lines.
If you need to put KEYS into the 88 & 89 KEY lines... do above and substitute 88 for the "08" line and 89 for the "09" line.
Post Number: 1178
here's what Posted keys looks like...VERY IMPORTANT INFO at bottom of post here..
BELL EXPRESSVU
12/23/05
Idea key 0:
20 2E EF 78 DA F6 38 3D
0D E5 30 FC FC B6 2B 68 ...Key is Active
Idea Key 1
BA 3A 15 E5 32 AC 6B FC
2C 93 E0 3C 80 A2 7F 24
DISH NETWORK
12-23-05
Idea Key 0:
AF 0C BD 48 D8 51 6D DC
FE 44 D6 0C A3 6E 59 42 ...Key 0 has become active 12/20/05
Idea Key 1:
FB D9 F2 D9 D6 C9 EF 7A
57 AD 32 24 67 42 6C E6
Globecast
00 0C A6 6D FF EF E9 4E C8
01 2A 93 49 EA A7 B9 15 EE ...N1 Keys????
VERY IMPORTANT BELOW!!!!!!
C*oolsat Slot 10 and 11 are for Idea Key 0 and Slot 20 and 21 are for Idea Key 1
Pansat key 00 for Idea Key 0 and Key 01 for Idea key 1
Viewsat line 08 and 09 for Idea Key 0 and lines 88 and 89 for Idea key 1
For Receivers with only two Key Slots, Enter Active Idea Key into 00 and 01
Post Number: 1179
PANSAT- IF YOU ARE AT NAGRAVISION, ENTER- THEN GO 2 TO THE RIGHT, YOU SHOULD SEE DISH NETWORK. BRING CURSOR DOWN 1 TO KEY NUMBER, SHOULD READ 00 AND THE TOP LEFT OF SCREEN SAYS NAGRAVISION-1, HIT THE RIGHT ARROW KEY 2 TIMES, SHOULD SEE 01, THEN 00 AGAIN SHOWING NAGRAVISION-2...ENTER YOUR CODES. IF YOU CANT LOCATE THIS AREA, YOU NEED TO FIND AND DOWNLOAD THE LATEST PROGRAM. CHEERS!
Post Number: 1180
How To Manually Enter Keys For Ariza:
Press
1- Green button
2- Red button
3- Red button
4- Menu button
5- Press right arrow several times until you see nagravision
6- Now depend on the key that changed and it is active you must scroll down til proper key to be changed
Example: On 06/09/05 ECM key 01 is active. Scroll down to provider 000101 01 key line and enter xx xx xx xx xx xx xx xx (enter number with your # button in your remote and for letter follow code definition button on your TV screen)
7- Press OK for 5 seconds.
8- Exit,exit...........
9- Enjoy
DN active provider in ariza flash is 0101. so edit keys in 000101 lines
DN key 00 is in 3rd line from top to botton
Key 01 is in 4th line
Suggestion Courtesy Of Yono:
How To Manually Enter Keys For Digiwave:
1- Press MENU
2- Scroll down to System Setting.
3- Press OK. If you see a red dot in the botton/left of your screen, go to step 5
4- Enter number 1004. A red dot will come out at ur bottom left. YOU DO NOT NEED TO DO THIS STEP w/ lastest bins.
5- Press red button (audio).
6- Press right arrow until NAGRA appears in the first line.
7- Down arrow up to Provider and right arrow up to 0001.
8-Now scroll down to first key line and press OK. scroll to the letters and number and enter Key 00. Get keys from Maestra or another site or using a key grabber program
9-Scroll down to second key line, press ok. and enter key 01
10- Scroll To Save Key and
11- Press OK.
12- Exit and Enjoy
Post Number: 1181
use Al7bar FTA Ultra_112005_284t3_12H_clock_api(NTSC)...or any one of the 282 bins...many bins will not "offer" U the Nagra2 screen to input keys, so use 282 or 284 bins to manully input keys now..
How to change the NAGRA2 Key codes
(for Fortec Lifetime Ultra only)
1- Press Menu button on your remote control
2- Press right arrow key 2 times Channel Edit
3- Press down arrow key button 2 times, press OK (Code) enter 1010
4- Press the down arrow key to Set Default Key, click OK
5- Press the up arrow key to Nagravision click OK
6- On your top left you should see Nagravision-1...if not, then you've got the wrong BIN version.
7- Press right arrow key until you see Dish Network on top
8- Press the down arrow key once to Key Number
9- Press right arrow key 2 times the from Key Number 00 - 01 - 00
( Now take notice that on your top left you should see Nagravision-2 now )
10- Then press DOWN button key to change the keys manually on Key Number 00
11- Enter new Keycode, do the same procedure to enter the the keys on Key Number 01
Note:
Satellite Providers changes the stream key codes unpredictably,
(Note: remote control key letters equivalent)
A = Sat, B = i, C = Tv/Radio, D = Pause, E = Audio (speaker), F = EPG
12- Check and make sure that you got all the keys....Press OK to store (save)
13- Press EXIT key 3 times to exit to the channels.
Note:
If you accidentally lock the KEYCODE (OFF) use this default password 1668
Post Number: 1186
Receiver Configuration set up
With the Receiver unplug
1. Connecting all the RCA cable from the TV to the receiver, and connect RG-6 Cable to the receiver, then
Plug in power cord on the receiver.
2. You should see the Language Menu on the TV screen, select English.
3. "CAS SYSTEM" set up, just following the 3A, 3B and 3C steps
3A). Press menu, scroll down to select Parental Control then press OK.
3B). Scroll down to PIN #2, then enter you 4 digits password.
If you enter correct PW, it will take you into the CAS SYSTEM menu windown.
3C). In the CAS SYSTEM menu, scroll down to SET DEFAULT KEY, then press OK. Then exit to main menu page.
In the future; if you have to edit the Dishnet key, just following the step #3 to get into the CAS SYSTEM menu,
to edit the key go here Here is how to update key with a screen shoot
4. From the MAIN MENU: selecting INSTALLATION then Antenna setup Option.
These are my dish set up and DiSeqC multi switch configuration;
DiSeqC #1 Echo8.6/Ku 110W,
DiSeqC #2 Echo7/Ku at 119W
Satellite: ECHO 6,8(110)
Lnb type-Standard
Lo freq-11250
22khz-OFF
DiseqC-#1
Skew: O
TP: leave it as is
Positioner-Disable.
Satellite: ECHO 7(119)
Lnb type-Standard
Lo freq-11250
22khz-OFF
DiseqC-#2
Skew: O
TP: leave it as is
Positioner-Disable.
5. Check the signal and Quality level highest as you can (adjust the dish slightly to improve the signal strength).
If you get no quality level on transponders, try others before giving up, because not all TPs are transmitting,
if nesscery Re-aim your dish still not getting any quality signal
6. Press the Exit button, press OK to save setting, the back to the Main Menu
7. Go back to the Installation Menu
8. Goto SATELLITE SCAN or BLIND SCAN, press OK, select the satellite to scan.
you have to scan all the satellites have, once it complete, you should be able to watching TV
Post Number: 1193
How To Change N2 Keys Ariza 700
1) Press Menu
2) Scroll Down to Parental Control, Press Enter
3) Press "i" key on remote, then enter pin number "2004"
4) Scroll down to Set Default Key, Press Enter
5) Scroll up to Nagravision, Press Enter
6) Press VOL Right twice, you will see Dish Network
7) Press CH Down once, then VOL Right Twice, you will now see Nagravision 2 displayed top left
You are now at the key 00, Press CH Down once so you can edit the Key Data
9) Enter your new keys (write down the old ones to be safe)
10) Press Ok to store, then repeat with key 01
11) Press exit until you get back to tv, all channels will be available
Post Number: 1194
Spacestar manual key change
Spacestar manual key change:
Press Menu--> Configuration--> Embedded Cas--> Nagra 2--> The press idea Dish Part1.
There you will see F1 & F2
Update F1 with the first 16 digits of the new idea key. Update F2 with the second 16 digits of the idea key.
After updating the keys, press "EPG" to save then press "EXIT" and watch tv!
Post Number: 1195
How To Change Keys Ariza 700
1) Press Menu
8) You are now at the key 00, Press CH Down once so you can edit the Key Data
N 0101 01 Bxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx (old keys)
N 0001 00 Fxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx (new keys)
THE LETTER BUTTONS ARE ON THE BOTTOM OF THE REMOTE!
Post Number: 1196
For Those Using The Pansat To Fortec Bins
Menu
Right side volume button to channel edit
down to codes
1668 or 1010
down to nagravision
right side volume button to DN
same as pansat except
A-Sat
B-Info
C-Tv / Radio
D-Upper Pause
E-Audio
F-Epg
Post Number: 1197
Digiwave:
1- Press MENU
11- Press OK.
12- Exit and Enjoy
Post Number: 1198
All Pansats
go to menu>>>
#1 parental control...
#2 go down to "second pin" option & enter 0000
#3 then go to nagravision...
#4 In Nagravision window go down to the box box that contains "00"
#5 While in the box (highlighted) that contains "00", scroll to the right till you see nagravision 2 at the top left of your screen
#6 While in Nagravision2 you should still be in "00" box and the number in that same box should be "00"...this is for Key 00
#7 Scroll down to key data and enter the new supplied key for 00 (within this site is the key change for Nagravision2)..take note on how to enter letters in the lower portion of the screen (ex. letter E=FAV button on remote)
#8 Once key is edited select OK button on your remote
#9 go back to the "00" box and move one click to the right which should take you to "01"..this is to edit the "01" key
#10 Follow Steps 7 & 8 above (this time enter key data for key 01 instead of 00)
#11 Click exit and click ok or yes to save changes then exit all the way out and you should be watching tv
Same thing will work with other Pansat models
BTW..If U do not see nagravison 2,then U need to put a newer bin in the receiver..
Post Number: 1199
How TO Guide: Pansat N2 key change procedure for Bin 123 & higher
These are ONLY sample keys
Key 00: 3D 73 19 22 27 5D C2 C9
Key 01: 97 96 5A 0C A5 79 27 F9
1. Press Menu button, then scroll down and Select Parental Controls goto 2nd PIN/enter 0000.
2. Scroll down to Nagravision 2, press OK.
3. On the Provider ID BOX, provider ID 0101,
4. Scroll down to KEY NUMBER BOX, you should have 00.
5. scroll down to KEY DATA BOX, enter the new N2 key00: 3D 73 19 22 27 5D C2 C9
6. scroll down to KEY DATA BOX, enter the new N2 key01: 97 96 5A 0C A5 79 27 F9
7. Confirm the N2 keys are correct, then press OK to save the new key. Then press EXIT a few times, and you will watching TV right away.
Post Number: 1200
how to enter keys manually for dn
ORASAT
sample keys only..
i got a lot of stbs need to take care of, so, this will be a short answer to the guys having problem to enter keys
to avoid problem, read careful and follow step by step and this not coming from the book.
while watching tv with all scrambled channels,6969, press blue key, scrow down to line 5 or provider 010100, index 10, press left volume key(left of ok), enter 10 3D 73 19 22 27 5D C2 C9, OK.
scrow down to line 6 or 010100 20, press left volume key, enter 20 97 96 5A 0C A5 79 27 F9, ok, exit.
if it does not work, try again; rememeber this, during the keys in if the key jumping to del (delete), it won't work. repeat the process til you unlock the access lock.
Post Number: 1201
Manually entering Orasat keys
MANUALLY ENTERING KEYS TO ORASAT 5
From any channel enter 6969 and then hit the blue key. Not in the menu. The first two lines will be for bev keys. Whatever the index numbers are reenter and then put the keys in. I did this and still don't get the bev. Others say they do.
For DN print out or write down the old keys and the new keys. Depending on what bin you are using you will look below and see what lines the old keys were. DN was line 3 to 8 on my 113 bin. On the 113 bin I was using it was line 5 and 6. Then enter the new keys in those lines. Don't do like I did at first and put 00 and 01 in for the index Put in 10 and 20 or whatever it says.
I also put in the channel list but still had to scan the sats to get it to come down. But with favorites it ain't no big deal. Never have been able to get a channel list to work. But after the scan of the sats I get all on dn. Hope this helps someone.
Post Number: 1202
how to manualy change Bev keys ...Orasat
as i promised, here you go.....
while watching tv, keys in 6969 takes you to cas menu; for BEV and DN press blue key on remote to take you in....
the first 2 lines(1&2) for BEV.
for example the index
00 EE 33 44 55 AA 66 77 88
01 BB AA EE 44 CC 66 77 88
is outdated and the current keys are
00 AE C9 B3 02 6A 2A 2D A2
01 0E 5E F4 E2 FA 13 8F 7F
to change it to the current keys, just goto index 00, press ok, use volume keys and channel keys to get to 0, hit ok, and just repeat the process til done then hit ok to save it. move to index 01 and do the same, are you guys feeling better now?
on Dishnet, I recommend not to touch it, not because of screw it up but for the coding dept continue to release update software and still have a job, sound reasonable?
just remind you guys the above example is just for info..
John Ann
4 example....what a useless thread this is...Its
time to close it....Fvcking Silly Thilly-e post
everywhere....Get a life.....Its xmas take a day
of come-bag....ROTF
Username: Greyhound
cannot find nagravision2, on pantec ??? anyhelp thanks
Post Number: 1205
READ...BTW..If U do not see nagravison 2,then U need to put a newer bin in the receiver..
Post Number: 1213
For Those that have ViewSat and are having problem with the new Dishnet keys...here's the answer.
press menu
then - installation
code is 0000 or 0937
then go to--code
then go to- nagra
at
nagra
Dish 01 01 00
00- B4 ED 24 E3 BC C1 82 69 ???? maybe old Naga1 keys
08--AF 0C BD 48 D8 51 6D DC ...Idea key 0
09--FE 44 D6 0C A3 6E 59 42 .............
88--FB D9 F2 D9 D6 C9 EF 7A ...Idea key 1
89--57 AD 32 24 67 42 6C E6 .............
Simply put DN idea key 0 into 08-09, and put Idea key 1 into 88-89....
If you don't fix the problem changing the keys is because your version is developing an error as soon as you change slot 08 and 09...in this case install v1024 (.pgm) using loader 2.
(the file is here)
http://www.dssrookie.com/forums/viewsat/vs2000_newosd_v1024-59851.html
(If you need loader 2 then go to here)
http://www.dssrookie.com/forums/viewsat/loader2-zip-60014.html
The instruction are included..... enjoy. let me know if your watching tv!!
Username: Motorhead04
thill do you know how to program x-dream 9000 sat.
Post Number: 1223
no, sorry..
If anybody has anything to offer about How To input keys...please post it here...so all the info for all the receivers will ALL be in this 1 simple thread/topic area...
Username: Sdgodfrey8
How do you add Bev keys to a spacestar receiver?
IK
Hi Thill, please tell me how to reprogram a dish network clone.It just went down all I get is the 500 channels.My guy who would do it for me has gone for a month.I have JEEPERS with TOMICO NAGRA 2 on my desktop. Up until
a few months ago I was able to do it myself.
Please help
IK
IK
can anyone out there help me as per my previous
message
IK
SUGAR DADDY
can't be any clearer!!!!!!
little ceasar
THANK YOU THANK YOU!!!!
LK!
LK!
LK!
YOU ARE THE BEST!!!
Username: Le74nguyen
Perris, Ca Usa
Post Number: 19
Do you have any new keys, please email me at
le74nguyen@yahoo.com can u post them on the internet
so I can get my TV BACK ON. Oh i also put
DishNetwork keys
KEY 0 = 3D 73 19 22 27 5D C2 C9
KEY 1 = 97 96 5A 0C A5 79 27 F9
nothing happend, all channels are still LACKOUT can
you give me correct key for pansat
2500A.PLEASE!!!!!!!!!HELP!!!!!!!!!HELP!!!!!!!
Perris, Ca Usa
Post Number: 21
Hi! sorry I am just new-because my sister bring for my family a pansat 2500a for enjoy a holiday- but she doesn't give us anything guide show how to down load and update bin... please if you don't mind can you show us step by step how to install and download... thanks we're appreciate.
I did connect between pansat with the cable to PC computer(printer) but I don't know how to intall to pansat software... please help me...ALL MY FAMILY NOW JUST WAIT YOUR HELP..
I JUST WANT TO LET YOU KNOW IAM A LITTLE AND DON'T KNOW MUCH ABOUT COMPUTER..THAT'S WHY CAN YOU PLEASE SHOW ME STEP BY STEP VERY CLEARLY SO MAY BE CAN I MAKE IT FOR MY FAMILY..THANKS AND HAPPY HOLIDAY TO YOU WITH ALL YOUR FAMILY!!!
Username: Lou
Toronto, Ontario Canada
I'm new at this so please be gentle. Just received as a gift the pantec ultra unfortunately with no support..I have the 119 and 110 setup but have no clue how to go into the steps to enter keys for a pantec.any information would be greatly appreciated
Username: Licha69
I am having a problem with my Pansat 2500 A, during the month of January I have lost the signal twice and currently I cannot see any of the channels, has there been a change ? Is there a new bin that I need to use ? currently I am using 256a, Please help !
thanks,
Letmeon
Have Pansat 2.56t bin . Cannot find place to enter for BEV (09 01) kys. Have to create new entry ?
Any ideas..........?
Username: Lklives
Post Number: 150
People...nows the time to read and LEARN this!...most receivers are included in this thread..if its a clone, then do the key change as if it were the real thing..
Username: Smokinvr6
how do you change keys on the bluejay 2. Please Help
Username: Mgmir
hei wat is the aux keys and haw we install this keys thank you
Username: Buzytee
i have a fortec ultra (model Jul. '04), was paying to have keys flashed. can i manually input the new keys? i'm trying to set myself up to use the computer, but i need more info.
E.M.T
thill do you know how to program the sonicsat pantec
Username: Tolirich
Anybody knows where I can download bin 140 please tell me. Thanks
Username: Lklives
Post Number: 277
John this is a topic/thread about "how To input Keys"...U should be banned for hijacking this thread...and asking a question that has been answered here 1000x!...READ!!!!!! LAZY!!!!
Posted on Sunday, January 22, 2006 - 10:02 am
This is the link to the 140 bin...U just simply upload from your computer to your receiver it using the BL v1.4 update sofware and your flash cable...1.4 is also at site below...
[link removed]
mmmm
Can anyone tell me if I can input keys on a bellexpressvu 2700 receiver manually
Thanks
Username: Cassey
Newark, NJ USA
I`m hard hearing and I use most of times Closed Caption.Please anybody know how to put Closed Caption on a Pansat2700A.Thank`s
Username: Lklives
Post Number: 292
I guess U can't read either...this thread is ONLY about manually inputting keys!...most sites would ban U for hijacking this thread!
Username: Cassey
Newark, NJ USA
Sorry I did not know about that.
I tought that should be a matter of pushing keys
because a friend of mine just have one with CC.
Once again Very Sorry I do not want to mess with anything. Cassey
Username: Lklives
Post Number: 388
Bump up
Username: Paramedic6399
Montreal, QUEBEC CANADA
HOW DO I UNLOCK BEV ON A COOL SAT 5000 ON NIMIQ 91
