Question on loosing sat.
Username: Hawks134
I have a 2700A pansat. I keep loosing one of my sat. One day echo 6,8 doesn't work than another day echo 7 doesn't work. I keep shutting it off in the back but it keeps one sat off. Some days both will work but not always. Any help
Beat_This
What kind of Switch are you using, it is most probably a switch problem you have. There are lots of multi switches that don't work properly switching between Satellites. Check out your Switch settings also on the menu. One more thing I would suggest you do is to hook every satellite separately to your receiver directly without using any switches just to see if your dish pointing is ok and everything is working. If you find out that both Satellites are working just fine without using the switch then it is to do with your switch.
Good luck!
