"Flash update Fail"? Help
Username: Mike1981
Toronto, Ontario Canada
Post Number: 7
I dl the bin File Type: AA-1_H20060107_264eEU_api.zip (344.1 KB, 26 views)
When i use the loader to upload the file i get the
message "Flash Update Fail". It wont even begin uploading the file. However when i try and upload another bin such as "AA-2_H20060107_264eEU_api" it begins to load. However the problem here is that the "AA-2 File" is for ARIZA 750 cx not for Ariza 700. Why can i not upload this file?
Loader version is 4.03
Any help would be greatly appreciated.
Mike
Username: Bizzylad
hi, every1, I have multistar pansat. I use echo 8.6 i would like to use echo 7 b-cuz i like the channels it has, if someone can plz. tell me how to convert to echo 7 i would appreciated alot.
Username: Slipperyer
Post Number: 9
I'm assuming that you unzipped the file.
Did you figure it out?
Username: Lklives
Post Number: 414
Thats usually is a defective or wrong flash cable or computer serial port..
