My tv flicker/blink on the sides of the screen
Username: Booker21
Post Number: 9
Edit:
Here is a video of how my "blink/flicker" problem. This happen only on the side, not the entire picture... and it goes from different range.. flicker badly, a bit, etc this depends.
http://www.fotosearch.com/CRT824/002434cf/
Username: Booker21
Post Number: 10
Hello all,
i have a HUGE problem, i bought this new tv, and it does the same thing my old tv did.. blink on both sides. This is not a TV issue, it`s more a interference of somekind since my old tv was at the service and they didn`t find anything.
What i notice is that if i set my monitor at 60hz it does the same thing, not that big, but blinks a bit on the sides. Also if i set my TV at 100hz, the blink goes away.
This happen on daytime usually while on night it looks fine. I`m certain it`s not the tv, again.. but i don`t know what kind of interference could make this.
I already tried to unplug all my equipement and leave only my tv but still the same problem.`It maybe somekind of outside interference... but how i can tell?
What do you recommend?
Thanks
edit
Edit:
Need to Register?
Forgot Password?
Enable HTML code in message
