Pansat 2500 "Can't pick parental Control"
Username: Madfrog
After uploading an update, screen changed and I'm unable to pick parental control or channel edit. Did try few different boot fixes without any sucess. those 2 options stay disable. Any ideas?
Username: Lklives
Post Number: 203
U were using wrong or old bin..
Load the 270 autoroll bin...and never worry about the keys again..they will autoroll in place whenever DN changes them...File is located in The Pansat "new file releases" area of [link removed]
here's the 270 autoroll bin with keys..upload , then let the keys roll..
[link removed]
channels
there has to be a channel list in order to "highlight" some buttons. like parental controls, and channel edit. you could either download a channel list, or just scan for a couple channels and press exit to stop, and your button will highlight.
Username: Lklives
Post Number: 213
channel...good advice.....yes of course U have to have channels/satellites scanned or a channel list in your receiver FIRST...if U had NO channels, there would be NO need to have "parental controls" or "channel edit"!...I presumed that much was understood..
