Ariza 700 New Key Input...
Username: Finestdj
Does anyone have this box working with the new keys..I'm trying but I can't seem to get it working...the N2 00 page has 2 rows of 16 number slots...the 01 also has 2 rows of 16 number slots...can anyone help...
Username: Slipperyer
You shouldn't have to punch in any keys if you are on the auto roll file. Make sure EMU is on and set default keys(press ok).
Username: Lklives
Post Number: 173
How To Change N2 Keys Ariza 700
1) Press Menu
2) Scroll Down to Parental Control, Press Enter
3) Press "i" key on remote, then enter pin number "2004"
4) Scroll down to Set Default Key, Press Enter
5) Scroll up to Nagravision, Press Enter
6) Press VOL Right twice, you will see Dish Network
7) Press CH Down once, then VOL Right Twice, you will now see Nagravision 2 displayed top left
You are now at the key 00, Press CH Down once so you can edit the Key Data
9) Enter your new keys (write down the old ones to be safe)
10) Press Ok to store, then repeat with key 01
11) Press exit until you get back to tv, all channels will be available
Key 0:
AF 0C BD 48 D8 51 6D DC
FE 44 D6 0C A3 6E 59 42
Key 1:
FB D9 F2 D9 D6 C9 EF 7A ..now the ACTIVE key 17 Jan 2006
57 AD 32 24 67 42 6C E6
