Missing Channels
Username: Rzoo4u2c
Post Number: 56
No Fox news or CNN
Grimreeper
do you have HBOE & W mabee its key roll time
Username: Rzoo4u2c
Post Number: 57
yes I have those WORKING
ciberman
there workin fine
Grimreeper
cnn is working cant find foxnews what channel is it?
Username: Rzoo4u2c
Post Number: 58
which they are?
Username: Rzoo4u2c
Post Number: 59
Two active keys in play right now.
not again !
key change coming
Grimreeper
205 works fine
I HAVE A AUTOROLL IN MY RECEIVER AND MY 110 IS WORKING FINE BUT 119 SAYS BAD CHANNEL SCRAMBLED YET SIGNAL STRENGH IS STRONG WHY IS THAT ?
Hello, I am new here. I have 119 working ok, however my 110 says after autoroll bad or scrambled channel. I would truly respect an answer.
Thanks in advance
Username: Thillisback
Post Number: 42
Did 110 work BEFORE the autorolled kicked in(which last key change was 23 Dec)..or did u lose it when U INSTALLED an autoroll bin?..and which bin?..and what type receiver?...clone or genuine?...and hardware setup?...and remote configuration?
tho_x_tran
I have both 110 and 119. I believe i am having some problem with the AutoRoll 051206_132 which I loaded yesterday. Right after that, I notice that some channels freeze for a few seconds, lose it (black screen) and comeback. CNN was lost late last night for a while, FoxNews was still lost, I have not checked if it is back. I used to have an older non-roll version of 051108_119 that I had no problem with any channel but the remote control seems stuck more often. The remote seems to work much better with the auto-roll 051206_132 though.
tho
just loaded 051213_140 seems to work fine. CNN and FoxNews are now back
