Installation of SUPERDISH 121
Username: Ssenow
Post Number: 11
Could somebody clear up this confussion that I have?
How would I connect the SUPERDISH 121 outputs to a 4/1 switch so that is could work with my Pansat 2700.
Grimreeper
hook 110 to port 1 119 to port 2 and 121 to port 3 the set it up in your receiver the same way you can use the 4th port for a single lnb dish and get bev to
