Where do I get C**lsat 4000 pro Bin Files
Jessica Notgniddaw
Could someone please give me the location that I could download the BIN file for my new C**lsat 4000pro? I have been looking for quite awhile. Please and Thank you
try kf2a.*om or dsscentral.*et
Username: Coolnewbie
I used to get a pop up menu when I turned on the C**lSat 4000 pro but ever since I did the "flashing" i only get snow on the screen. WHat can I do? I can't even set it back to factory default. plz help
Jessica Notgniddaw
Thanks will try that.
Jessica Notgniddaw
Thank you I will try those sites. Cheers!!!
