Does anyone have the BEV Keys?
Username: Ikaleem
Post Number: 9
All my chaneels are coming scrambled
Username: As400
Post Number: 65
New BEV IDEA Key: BD E1 CA 94 04 E7 C3 D5 A9 A1 C9 2F E4 B6 37 27 (11/28)
Username: Johnydepp
Post Number: 26
Where did you get these new keys from IBM?
saks4545
is there a clone safe pansat file out for bev yet i have been looking up a few sites but nothing so far can somebody help please?
Username: Timscarlet
Dayton, Oh Usa
Post Number: 154
Echostar N2 keys
Key0: F2 98 74 44 1C 65 77 D8
Key1: 17 E3 E1 1D 89 4E 53 45
Nimiq N2 Keys
Key0: C2 F3 C8 33 34 1D 3E 93
Key1: 85 30 2D 0A B1 DA EB BC
JUST ENTER THESE NEW KEYS IN THE NAG2 AREA, JUST LIKE YOU DID BEFORE.
THESE ARE THE KEYS TO THE BEV, THIS NAG2 KEY STILL WORKS WITH DISHNETWORK, JUST MAKE SURE YOU PUSH THE DEFAULT KEY ON PARENTAL CONTROLS MENU, BEFORE WATCHING CHANNELS., TIM
where do i update my b3v keys on a vs2000? Please help!!
Username: Ikaleem
Post Number: 11
Keys posted by Tim are not correct. Here are the right ones
Bde1ca9404e7c3d5a9a1c92fe4b63727
Username: Rossyjess
hi
I have a pansat 2500A and i flash the bin 260 but i don't know how to get bev I put the keys and doesn't work please if anybody know how to doit I blin scan the clannels but went i want to see is message in the sceem bad scrambler channel please help me what I can do.
keymaster
the keymaster program says bev keys are changing so rapidly, it might be hard to keep channels on bev.
Caribo008
forget about BEV for now, they are changing keys every 15 minutes and sending ECM's as well so wait until they have a autoroll solution to this. BELL must be mad that's why they are doing this.
Username: Hamtec
Post Number: 298
Bev only did one key change yesterday they are not changing keys every 15 min. But you are correct there is a ECM in the stream.
Changing Keys
There was a lull, they are back at it again changing keys every 15 minutes or so.
An autoroll fix is being worked on now.
