Help choosing a screen
Username: Hogwild
Post Number: 15
I am installing a sony Cineza vpl-hs51 in a light controllable (narrow) room.
I need a screen. What would be my best choice.
White vs grey, what gain etc.
I know I liked the stewart firehawk that was on display - but would like to keep the cost under $1000.00
brett1437
I can't rember the cost but have you looked at Draper or Da-Lite? You might want to check out www.digitalhsolutions.com.
Username: Mike1234
If you have the option pick some flat white paint, and paint a screen. Use a couple coats, im very impredded how good it looks. i made a border spray painted it flat black. For under $20 this compares to some of the best screens out ther. People come over and touch it because they think its a real screen.
Need to Register?
Forgot Password?
Enable HTML code in message
