Went to RadioShack
Username: Mac42718
I bought the RS-232C Cable with female db9 to female db9 ends...will this connect to the back of my pansat 2700a? I have a new dell computer less than two months old...on the back of the computer there is a connection that has the same female end of the cable. Do I need to purchase an adapter?
Username: Thill1951akalk
Post Number: 916
U need a null modem cable!...or adapter to use on a straight cable...FTA 101..
Username: As400
Post Number: 60
I imagine you can only plug a serial cable on a serial port... I dont think newer computers come with serial ports anymore... Your Pansat 2700A was supposed to come with the cable. Why did you have to go buy one?
