FORTEC KILLERS (on purpose)!!
(Quote)!
No File yet for Fortec...
I have tried every file in this section, and I had to jtag every time after.
People IF you have a FORTEC that has BLACK not SILVER screws holding your box together, and it is dated August 2004 (or very close) you should be fine.
Every fortec that had SILVER screws DID NOT TAKE THE FILE. ONLY THE FORTECS with BLACK SCREWS took the file.
ALSO, FILES that state they have had the clone Kill removed are CORRECT, they DO work on PANTECS, MULTISTARS, cooltecs, and the miriad of PANSAT CLONES.
HOWEVER, THIS FILE TARGETS ORIGINAL FORTECS PURPOSELY!!
I bet a good 30% of fortecs have gone down due to these files.
DO NOT FLASH YOUR RECEIVERS UNTIL A FILE IS CONFIRMED WORKING ON NEWER MODEL FORTEC ULTRAS.
good grief....
my fortec has black screws holding the box top cover. If this is ok, then where do I find the date you mention?
Thanks!
Username: H3lt3r_sk3lt3r
Post Number: 775
There's supposed to be a sticker in the back of your receiver with the manufactured date on it.
fishyguy33
ok i have one that i know i bought in 2004 has black screws buttttttt i have a brand new one that also has black screws there goes your therory
jiji
me too. I got one a week ago that has black screws too!!!
Please help
LK's bud
Blacklist said he will intentionally kill all fortec's but U would know that if U had read at other reputable forums.
Boycott this forum, go to [link removed] or [link removed]
